Looking for an internet provider
SOURCE: opening ports on 4100
Thanks for the information. I'd recommend obtaining a router, it would make your life easier because routers are made to do exactly what you're needing to do (split your internet connection among several devices (PS3, PC, etc.). I'm a fan of Linksys routers, I use them in every home deployment possible. You can find the Linksys WRT54G or some variant at any big box store (Best Buy, Circuit City, etc.) or at online retailers (NewEgg.com, Buy.com, Amazon.com) for real cheap. All you'll need to do is hook up your router to your ISP'd modem, hookup your PC & PS3 to your router, enabled uPNP (universal Plug & Play) on the router and you're set.
You could use your PC as a router (assuming your PC has two network cards in it). You just turn on Internet Connection Sharing (ICS) and specify which card is connected to the ISP's modem (internet) and which one is connected to the PS3 (internal network). I don't recommend this solution as it is a bit buggy and having to route all the data from PS3 through your PC degrades the online performance on both the PC & PS3.
I hope this info helps, let me know if there's anything else I can do to help.
SOURCE: trouble setting up internet browser on my i9b phone
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit ProfileWAP
***First Step***
11. Save
***Second Step***
Select WAP
Select back or done
MMS
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good
Select Done or Save
For full help topics I have a cd available fo 10 us dollars. Has 100's of mp3 ringtones wallpapers, and java games. Guarenteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope.
SOURCE: at&T says I must subscribe to their
I have AT&T and I use my own linksys router. For dsl you will need to set the router for pppoe and you will need your user ID and the password from AT&T. Also turn on DHCP on your router.
SOURCE: cannot browse the internet i should subscribe to
Here is the procedure for subscribing to packet data:
Menu--settings--connectivity--packet data--packet data settings--edit active access point--packet data access point. Once you are at this point you will be required to type in a name for your access point: Type in "Internet" and then save your settings and exit back to standby screen.
You should now be able to browse the internet.
Best wishes,
Graemevm
SOURCE: internet access problem
Unplug power from the modem AND the router. Plug in the modem and wait until all the lights turn on (except if there is an activity light). Then plug in the router. Reconnect to the network from your computer.
I do not have the product but I am interested in possibly using the Better 44
