Question about RCA TruFlat 27F520T 27" TV
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
I don`t have the remote just using the button`s on the T.V. need it to go to channel 3 or 4 but won`t change.
Posted by knightimeaging on
Jessie Nisperos
    New Friend:
    Problem Solver:
  • 3 Answers
Try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
Posted on Jun 04, 2016
5 Related Answers
Anonymous
  • 1284 Answers
SOURCE: TV (RCA model F32705) stuck on one channel
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Posted on Apr 26, 2007
Anonymous
  • 48 Answers
SOURCE: RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Posted on Jan 25, 2008
Anonymous
SOURCE: RCA HDTV Tru Flat 27"
Mine just conked out . Cheap Chinese junk from Wallies
Posted on Apr 27, 2008
Anonymous
SOURCE: rca 27 truflat
This didn't work for us, very sad..
Posted on Jul 23, 2008
Anonymous
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
No cable
does the set have audio/video input jacks on it?
The only channels available are throu ch 2-13, I have tried doing numerous auto searches. and have tried to restart it. I checked the cable, everthing is plugged tightly and nothing is frayed. It has done...
Make sure the TV is set for "CABLE" or "CATV" tuning. I forget on this model exactly where in the menus the setting is. Sorry. But it's usually in a general setup page, or part of the channel setup. If the TV is set for "AIR" or "ANTENNA" tuning, cable channels 14 and up won't be detected.
1helpful
Can't get channels.
You need a converter box on that unit.
2helpful
Audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
My rca tv
The remote control may only work for the cable box and you may have to manually put the TV on the correct input channel also you might double check that the cable to the TV is hooked to the antenna input. Here is the website for the manual TV if you think it might help.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
2answers
Only get about 4 channels
Make sure in the on screen menu that the tuner is set for CABLE or AIR depending on whether you have cable or an antenna. The channel frequencies are the same for ch 2 thru ch 13 but everthing above that is different depending on your source.
Hope Ya Fix It!
I only get about 5 channels
Hope Ya Fix It!
T v channel
Tuners are a big source of problems on this model, i may suggest using your cable or sat box as the tuner by going from the video out of the cable or sat box to the video input on the tv, select video on tv and let the cable box1.gif or the sat box act as the tuner, if you are using outside ant then use a vcr as your tuner to the set. this is a easy and cheep way to fix your problem.
hope this helps ya.
2answers
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
