ask repairman to give you total bill for fixing your washer an compare that total to buying a new washer I look up how much it would cost for a new Electrolux washer it would be cheaper to fix your
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting! Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ... www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sub Hopper Toner motor mechanism malfunction.Remove rear cover,pull out toner cartridge,Remove sub hopper unit fixed under main hopper toner assembly and change the sub hopper motor or the agitator levers gears.
E020 General condition 1) Is the developing assembly locking plate mounted correctly? NO: Mount the plate correctly.
General condition 2) Is the shutter releasing member of the hopper mouth mounted correctly to the developing assembly locking plate? NO: It is likely that the inside of the hopper is clogged with toner. Remove and then mount back the shutter releasing member to remove the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1) 3) Is the developing assembly adequately provided with toner? YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2) 4) Is the hopper adequately provided with toner? NO: Check the hopper toner sensor. Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal? NO: Connect the connector securely. YES: Check the hopper supply motor.
Error 045 motor not follow
