Question about Nokia 3100
The phone is locked
Not start without putting code
Forgot phone lock code
what model is your phone ?
Feb 02, 2012 | Cell Phones
I switched off my samsung S8300 and then it lockd the phone
very easy just put this code without card sim *2767*3855# and the code being 00000000 if ur problem not solved just put this code to reset eprom network *2767*2878#
Jul 06, 2010 | Cell Phones
How do I unlock my samsung impression?
if you set the pass code on the samsung then what you need to do is take it to AT&T store. and ask them to remove unlock code. aka phone lock system.
Jul 04, 2010 | Samsung SGH-A877 Impression Cell Phone
Putting a lock code on an e71 to unlock phone
It is possible to put code on E71, You go to settings then security, you will enable the keypad security code and enable your phone code also. With these nobody can access your phone without asking for security code. Take note Phone, sim and keypad pin code must be enable. Thanks
May 13, 2010 | Nokia E71 Smartphone
Hello, i tried to reset my chinese nokia E77, when the phone starts, ils asks me an input phone lock code. I have tried the following codes without success : 1122, 3344, 1234, 5678, 0000. Would mind...
Thank you for your solution proposition and your help. I have put the code and the phone works now.
In fact, it was a problem of a wrong code. I forgot i put my birth date.
Thanks a lot,
John
Feb 04, 2010 | Dual Lands Phones
HI Please help me unlock my Nokia 3120C! It asks for the security code which I don't know. IMEI : 353102028122050
Try the reset code:
*#7328748263373738#
Then your securtiy code should be reset to :12345.
Please rate my solution if this helps.
Sep 10, 2009 | Cell Phones
Samsung e250 simlock code to unlock
1.insert this code *7465625*28782# without sim card.
2.the phone will show you message of protected activated,click o.k.
3.again insert the same code without sim card.
4.now put in your sim card.
5.when you put in different sim card(network),phone will ask for code,insert all the 0's phone will work on any network
Hope this works for u
Aug 06, 2009 | O2 Samsung SGH-E250 Cellular Phone
I NEED PHONE LOCK FOR T MOBILE G600 SO I CAN PUT VODAPHONE SIM IN
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
Tested with few pieces
Feb 08, 2009 | Samsung SGH-D600 Cellular Phone
I put a lock code on my mobile but i forgot what i put.plaese help
hi Beckki,
There is only one way to access your phone without losing your data in your phone:
   Block your sim by entering wrong lock code and then it will ask for the PUK code that you will get from your service provider. Enter that PUK code and your phone is unlocked.
Thanks...
Aug 28, 2008 | Lands Phones
Nokia 3100 Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
