Washing Machines Logo
edward pattrick Posted on May 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint wma48 shuts down anywhere during cycle
Washer shuts down during wash cycle sometimes during rinse/spin cycle not always at same point of cycle. Code states door lock problem but this has been replaced with a new one ,. Any ideas as to why shut down . But washer can be restarted after leaving for half an hour or more but again shuts down
Bob Williamson
Level 2:
Habit-Forming:
New Friend:
  • Expert 138 Answers
  • Posted on Sep 04, 2016
Bob Williamson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
138
Questions
0
Helped
36322
Points
251
Which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 26, 2008
SOURCE: Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Anonymous
  • 525 Answers
  • Posted on May 27, 2008
SOURCE: aggitates but does not spin out to rinse
From the description of your complaint, I would replace the timer to correct the malfunction.
Anonymous
  • 1543 Answers
  • Posted on Sep 23, 2008
SOURCE: my lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Anonymous
  • 6 Answers
  • Posted on May 08, 2009
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Anonymous
  • 6 Answers
  • Posted on Jan 19, 2010
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
LG WM3987HW Combo - drum is filling with water during dry cycle.
Sears Parts Direct is one source of the parts diagrams, https://www.searspartsdirect.com/model/1vc37q1bdj-003204/lg-wm3987hw-washer-parts . See the Dispenser assembly parts diagram for the water inlet valve. If you can watch the entire cycle, try turning off the shut-off valves for the washer inlet hoses after the rinse cycle and before the dry cycle starts. Water should not flow into the washer/dryer with the shut-offs closed.
I've seen inlet valve solenoids fail in the open position or in the closed position. I've never seen a control board that sent open messages randomly. (Sometimes, there is damage to the control board or corrosion or damaged wiring that stops the control board from sending the open/closed message to the solenoid.)
I hope this helps.
Have a hotpoint aquarius wml540 that is stopping on the rinse cycle, when it stops the rinse light is on and the red lock light is flashing, is this an error code?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
2answers
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Will not go onto final spin on its own
check drain hose lid switch ....plugged pump or drain hose last timer
2answers
Hotpoint WMA48 Washing Machine
Push the door handle in once with your knee - this is required to make it start. It's not a fault.
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
