Question about Home Security
Is it possible to reset the admin password for iptec dvr model: IPD-9RTH
Posted by limneshk on
Andrew Taylor
    Top Expert:
  • Home Security Master
  • 34,000 Answers
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: I have an Eyemax DVR 9120. I forgot the admin
c:\windows\dvr2 i think is the file that saves the password
Posted on Apr 08, 2010
Anonymous
  • 5 Answers
SOURCE: i have an eyemax dvr .. i cant get to the admin
In the C:\Windows and look for DVR2.ini file. Open the file and scroll to the "Users" section and look for admin and replace all of the information next to the "=" with:
61646D696E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000FF130000FFFF00000000000000000000000000000000000019
This will replace the current password with a blank password.
Posted on May 26, 2010
Jon Lang
  • 24 Answers
SOURCE: Hi can anyone advice me
Get the 12 digit alpha numeric mac address off of main board and call your tech support. They should have, as I do, a keygen for the master password for that main board. Any reputable dealer will have the MacCov program from Rifatron.
Posted on Dec 27, 2011
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: i forgot my admin password for mycam dvr 360V. default password?
0000
Posted on May 31, 2015
SOURCE: Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Posted on May 14, 2016
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
IFORFOT ADMIN PASSWORD FOR MY "XVISION MODEL:16D" PROFESSIONAL 16 CAMERA (4 AUDIO) H264 DVR - PLEASE HELP
You need to be good to do it
http://www.xvisionconsulting.com/obiee/reset-admin-password/
Sep 28, 2015 | Home Security
I have forgotten the admin password of dvr (H.264) TIME IS 30-11-2000000
admin
The default password for EVERYTHING is "admin"
(it means "administer")
Don't ask me why. I dunno.
or "admin" for "user", and just leave the space BLANK for password.
best 'o luck, Amir
Feb 13, 2015 | Home Security
264 dvr password
There isn't a "super password". There is a default admin password of 00000. That said if this is a used device and the default password has been changed, there is no way to reset the password, at least not from the GUI. It is possible the embedded linux that is installed on this DVR can be flashed. I'd contact the manufacturer if this is the case.
Aug 28, 2014 | Microsoft VISTA Computers & Internet
AlienEko 308 DVR forgotten passwords.
Here is the operations manual. I believe section 12.7 gives instructions on how to reset to factory defaults.
http://www.lymebayalarms.co.uk/?wpdmact=process&did=OS5ob3RsaW5r
Jan 12, 2014 | FPS 4 Channel Standalone DVR system,...
How do you reset the admin password on a truvision dvr 30 16 channel.
how do i reset admin password on a truevision dvr.
I have changed it and i forgot it
Jun 29, 2011 | GE Security Kalatel TVR3008500 TruVision...
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
542 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
