Computers & Internet Logo
M
Mike Barg Posted on May 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for a service manual & electrical schematic for the Lambda Model LS FM3 Regulated Power Supply.
This power supply was manufactured in the early 1990s but I could not find a manual or schematic online or from TDK-Lambda. I am attempting to repair a unit but this is difficult and inefficient without at least a schematic.
David Payne
Level 3:
Top Expert:
  • Power Master 14,162 Answers
  • Posted on Jun 30, 2016
David Payne
Power Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2994982
Points
455836
5 Related Answers
Anonymous
  • 482 Answers
  • Posted on Mar 15, 2008
SOURCE: Power supply stopped working
most of the time you need to replace the mother board as well as the power box, it shorts the mother board out.
Jalal Sordo
  • 1800 Answers
  • Posted on Aug 18, 2008
SOURCE: Austin power supply model:DR-B300ATX
http://compreviews.about.com/od/tutorials/ss/DIYPSU.htm
dont forget to rate this post
Anonymous
  • 948 Answers
  • Posted on Jan 20, 2009
SOURCE: how can i determine if my power supply is dead?
You can see the pinouts for the power supply here.
Anonymous
  • 6 Answers
  • Posted on Sep 07, 2009
SOURCE: i need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Anonymous
  • 557 Answers
  • Posted on Dec 14, 2009
SOURCE: Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Testimonial: "Your solution worked perfectly Thank you very much Bill"
Needs Service Manual with Schematic diagram of i ball SMPS Model no.LPE 223 - 400
I'm sorry, but I am not able to provide specific service manuals or schematic diagrams for specific products. I would recommend contacting the manufacturer or a authorized service center for assistance with obtaining a service manual or schematic diagram for your specific device. They may be able to provide you with the information you need or point you in the direction of a resource where you can find it.
In general, when troubleshooting issues with a power supply, it can be helpful to check the voltages at various points in the circuit to determine where the problem is occurring. If you are not getting the expected voltages at certain points in the circuit, it may indicate a problem with the power supply or with components downstream of the power supply. You can use a multimeter to measure the voltages and compare them to the values specified in the service manual or schematic diagram to help diagnose the issue.
What capacitors are used in power supply
The DAB 211 FW DAB radio is a digital audio broadcasting (DAB) radio that uses a power supply to operate. The power supply is typically an external device that is plugged into an electrical outlet and connected to the radio via a power cord. The power supply provides the necessary voltage and current for the radio to function. The specific type and specifications of the power supply will vary depending on the manufacturer and model of the radio. The service manual for the 1816B Case Skid Steer will not contain information on the power supply for the DAB 211 FW DAB radio. You may contact the manufacturer or a local electronics repair shop for more information on the power supply for the DAB 211 FW DAB radio.
Switched on Resmed H5i S9 Autoset CPAP machine and shows error check power supply is plugged in
That unit is specialized and proprietary and you will not find any information to service it yourself. Since it is licensed and considered medically regulated, you must return it to the manufacturer for repair
Mar 19, 2022 • Humidifiers
1helpful
Want the schematic of the power supply for this model.
You'll need to know the model name and number of the power supply...if the info is not on a decal on the power supplies cover, open it up and check for any imprinted info- just make sure the power supply is unplugged when you open it up; then you can either:
  • Google the info;
  • check various online manual libraries
  • direct contact support with manufacturer
Schematic diagram example of AC DC regulated power supply 1.5volt to 35volt
You will need to add transformer and rectifier diodes before this circuit to be able to get the voltage you need.
See the link below of the regulated part of the circuit
http://simpleelectronic.com/2010/06/11/simple-adjustable-regulated-power-supply-circuit-diagram/
If you need more help let me know.
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Along the top of the picture on the screen is green, how can we get rid of this please.
You are saying about a horizontal green belt acorss the screen at the top. It can be due to main power supply [regulated power supply inside your tv]. Check it whether proper power supply is there or not. Normall it shuld be between 110 to120VDC. Different manufactures have different operating voltages. You should refer to the schematic digram of your tv.
An other cause ca be the lack of voltage, or improper voltage to vertical output section. I thing that you haven't replaced the deflection yoke of your tv till now. If deflection yoke have been replaced, convergence assembly at the neck of the picture tube should be aligned properly to rectify this probelm. Contact an experienced service personal. Ok.
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
6helpful
LG TV (LCD) power supply schematics
Service manual from SAMs does not include a schematic of the power supply board
Top Power Computers & Internet Experts
vince
NOEL
NOEL
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
