Nakamichi SoundSpace 9 CD Shelf System Logo
Question about Nakamichi SoundSpace 9 CD Shelf System
How do I open the cd drawer to remove a fallen paper clip
Posted by Farouk Khan on
Ravi
  • Nakamichi Master
  • 1,682 Answers
Posted on Jun 04, 2016
Grubhead
  • Nakamichi Master
  • 5,720 Answers
If you do a google search for "Nakamichi SoundSpace 9 service manual" you will see a PDF file that shows how to dismantle the unit so you can get the item out.
1 Related Answer
gopakumarg43
  • 76851 Answers
SOURCE: How do I open the CD drawer on my Nakamichi SoundSpace 9
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on May 22, 2016
2answers
How do you open the CD drawer?
There is a button on the drawer. It is located near the center toward the bottom. It is often difficult to see. I painted mine white using "white out" error correction liquid. If the drawer is not opening after pushing the button then use a paper clip to aid in the opening. Insert the point of the paper clip into the hole that is next to the drawer eject button as described above.
2answers
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
1helpful
My cd draw will not open
Hi wmickie49...
Straighten out a paper clip, look at the cd drawer...there will be a very small hole somewhere on the cd player/burner...insert the straight paper clip into that hole and your drawer will open.
Please take time to rate me
My CD writer will not open to insert the CD. What
Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
The cd player want open
Turn the computer on.
Take a invented-in-Norway paper-clip, and straighten one end.
Put the end into the small hole in the front of the CD-drive.
Push it gently in until you feel resistance.
Then, push much harder, for about 1/4 of one inch,
and the drawer should open, slightly.
Remove the paper-clip.
Gently pull the drawer open.
Remove any CD from the tray.
Then, remove the CD-ROM device from the desktop, and discard it.
DVD/CD drawer does not open when button pushed - Averatec 3360
this is an issue with the tray release, built into portable disk drives. I would recommend replacement or repair by a good technician.
-this is not a software or firmware issue.
-this is an actual physical damage to the tray mechanism itself.
hope this helps you out.
CD drawer will not open
Most CD's have a small hole in the front of the drawer cover. This hole can be used to open the drawer, straighten out a large paper clip (wire style). About 2" should be enough! Put he paper clip end thru the hole perpendicular to the front (straight in). You will feel resistance at about 1/2" to 1", pressing firmly (don't jam it in), the drawer will start to open as you press the right place, gently pull the drawer open. If something is jammed inside, removal and possible replacement may be required. If you don't feel confident in opening the case, don't!
Top Nakamichi Audio Players & Recorders Experts
David Shaub
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
