Question about Suzuki Motor, Power Trim, DF60-70 98-00, DT65-75 95-97, DT85 95-00, DT115-140 96-01
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
Posted by Wayne on
Marvin
    Top Expert:
  • Suzuki Master
  • 85,239 Answers
Check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
Posted on May 22, 2016
  • Wayne May 22, 2016
    Guess I will take to dealer on Monday . No over revving that I know of.
    Thanks
    Wayne
_-__-___-_
  • Suzuki Master
  • 20,706 Answers
Wow photos, we never get real photos here,
what a great deal that.
a suzuki 60 is not a car, nor is it a truck
must be guess what it is?
an outboard motor?
a DF60 ??? left off the DF?
moving you.
Posted on May 27, 2016
5 Related Answers
fixcar001
  • 202 Answers
SOURCE: 1992 EX Check Eng. light comes on Eng. quits
When your engine not starting or quits while you driving check to see any sparks, or remove the distributor and let the auto part test it. if it no sparks or the auto part say is bad , replace it.
Posted on Mar 31, 2009
Anonymous
SOURCE: WHEN STARTING, CHECK ENG LIGHT,COOLING FANS COME
coolant senor
Posted on Nov 16, 2009
Testimonial: "WORKED GREAT"
carl
  • 3640 Answers
SOURCE: engine coolant temp interm
the engine coolant tempurature sensor may be failing, the reason why truck stalls when light comes on is that the pcm thinks there is still a problem, then shuts down. after replacing sensor erase problem code with a obd2 scanner. if you do not have access to 1 you can go to any auto parts store and they will turn light off for free.
Posted on Dec 11, 2009
Anonymous
SOURCE: i HAVE suzuki xl7 2007 and 1 time a 3-5 monthes lamp check engine
i had this problem then my stability control warning came on next therefore turning off my awd .... it was a wheel bearing .. ask for chev equinox parts they r half the price ..the suzuki is compatible with the equinox and torrent....
Posted on Dec 13, 2010
brian hunter
SOURCE: I fueled up my 2007
The check engine light can come on for many reasons. I would try tightening my gas cap first. If that doesnt work you can go to autozone or a local parts store and have them pull the code. Usually this is free.
Posted on Aug 15, 2011
Mahindra scorpio
Start by checking all ground connections from battery on back. When you say it does not start, does it turn over or not? All your dash lights go through a test first, make sure they are working before trying to start the eng. If this is the only one that doesn't light up during test it could be the temp sensor in the eng block or the wiring to the temp.
Nov 09, 2013 | Cars & Trucks
1981 TS 185: i have a 1990 suzuki ts and the eng wont turn over...
check to see if gas is flowing from gas line make sure fuel tap is turned on. Check the plug and replace it if not new check to see if the carburetor is dirty. Make sure if you have an oil injector to check the oil lines. To name a few things.
May 18, 2010 | 1981 Suzuki TS 185
Blower fan has no output. Temp guage not working
for blower motor check fuse hvac 20a int.panel and hvac 30a fuse in elect.center eng.compartment,if ok,check for 12v at blower connector if power is there fan is defect..temp.gauge check connection at unit if ok check resitance if it varies when engine warms up,if it doesnt vary replace unit,if it varies check wiring circuit,unit is place at drivers side of eng.block near sprk plugs.for hard to start;if check eng.light is not on could be in need of a tune-up depending on how long ago it was done,if check eng light is on or was on scan ecm for trouble code.
Oct 03, 2009 | 1999 Chevrolet Blazer
I HAVE suzuki xl7 2007 and 1 time a 3-5 monthes lamp check engine
Jun 14, 2009 | 2007 Suzuki XL-7
Mar 29, 2009 | 1992 Honda Accord
Check engine light
  1. ENG NOT START LIGHT COMEING CHECK ENG IT IS FLASING. HOW CAN I SOLVE THE PROBLEM
Aug 19, 2008 | 2000 Suzuki Swift
Vw polo 1997 not starting 1.9 d
Check for shorts in the plug wires.
May 06, 2008 | Car Audio & Video
Suzuki Motor, Power Trim, DF60-70 98-00, DT65-75 95-97, DT85 95-00, DT115-140 96-01 Logo
517 people viewed this question
Top Suzuki Boating Experts
Marvin
Marvin
jws1013
Andrew Taylor
Andrew Taylor
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
