Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn air s136 stove won,t self clean
All functions work except cleaning . fan comes on when clean selected . lock door but no lights come on and oven does not heat up. any ideas?
Posted by jfisher915 on
  • 5 more comments
  • Anonymous Nov 25, 2007
    Identical problem with a Jenn-Ari S156. all functions work except cleaning . fan comes on when clean selected . lock door but no lights come on and oven does not heat up.
  • Anonymous Dec 04, 2007
    I have the same problem, I put the Jenn-Air stove into cleaning cycle, locked the door, hit start twice, fan turns on put no cleaning cycle.
    Ed
  • Anonymous Jan 30, 2008
    Have the same problem. The Jann-Air website doesn't even find the model in their product catalogue (was looking for a manual).
    Check the door locking latch, works ok. Would love a workable solution
  • jas99 Apr 02, 2008
    does anyone know if the s136 has a motherboard? can't find any manuals on line
  • Billbhrv Apr 08, 2008
    I have the same problem except for the fact that when I move the lock over it buzzes and will go completely into the lock position. Therefore I can't set the timer either. We have the Model S136.
  • Anonymous Nov 25, 2008
    have wiring diagram, email me if needed.
    Harold
  • Anonymous Mar 27, 2014
    Clean inside of oven door DUSTY!
ivanandjayna
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
  • ivanandjayna Mar 21, 2008
    I was troubleshooting my stove and found the wiring diagram under it when I pulled the stove out. Let me know if you still need a wiring diagram. A mouse chewed a couple small holes in it, but it's still pretty legible.
    Ivan
Anonymous
    New Friend:
It's the clock. Had the same problem. Replaced the thermostat etc., finally went for the big bucks and put a new electronic clock in which literally controls everything and the old S136 cleaned like brand new!
Posted on Jan 16, 2010
Anonymous
I have a Jenn-Air model S136 don't have manual how do I use the cleaning method on the oven. Do I have to use oven cleaner?
Posted on Aug 07, 2009
Anonymous
THE FAN WONT SHUT OFF
Posted on Mar 27, 2008
Anonymous
Jenn-Air rep told me they do not release the wiring diagrams for proprietary reasons. I had a certified technician in and he didn't have the diagram either. He had to shoot in the dark and now the oven doesn't hold temperature well. Since a Jenn-Air competitor could reverse engineer the design simply by buying a unit and taking it apart, Jenn-Air's no release policy seems to be aimed more at making their ranges unrepairable. Maybe they think this will create more sales.
Posted on Jan 10, 2008
Anonymous
  • 26 Answers
Its hard to diagnose a self clean problem. Might be a door lock switch causing problem . Have to read those wiring diagrams and trace electrical path .
Posted on Jan 09, 2008
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
Self Clean won't start
Sounds like a control board problem
Nov 10, 2017 | DCS RGU-486GD-L Range 48", 6 Burner,...
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Self Cleaning light comes on and flashes when you turn on oven!
It sounds like you have a defective Oven control module. (TO8 Control) is the part that controls all oven functions including clean,clock,timed bake, ect. Item is easy to replace yourself.
Mar 29, 2009 | GE Spectra JBP78 Electric Kitchen Range
OVEN WILL NOT CLEAN JENN-AIR SVE47100B
It was recommended to me by your service that I call a service person. I did that. thanks.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
2,735 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
