Question about Garden
I have a black and Decker pressure cleaner pw1500. Oil needs replacing in the motor pump. How much oil needs to be replaced and what type of oil?
Posted by Philip DosSantos on
  • Philip DosSantos May 21, 2016
    Hi, thanks for your reply, I had to replace all the seals as lime scale build up damaged the seals and started mixing the water with the oil. I have replaced all the seals and cleaned up the pump. I now need to replace the oil.
Pcm2048
  • 753 Answers
What makes you think the oil needs replacing. These pumps typically are sealed and have no servicing requirements. You one uses a 3 piston wobble pump which I suspect will have a grease packed bearing in it. (I haven't checked your one, but this is common in these pumps)
Posted on May 21, 2016
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: oil pressure
does the engine make any raddle noise when you start the engine. if not may just need oil presure sensor.
Posted on Jan 01, 2009
michigan man
edgar walker
  • 3533 Answers
SOURCE: I NEED TO REPLACE THE OIL PUMP ON MY 1998 CHRYSLER 300, HOW DO I
first of all put the car on ramps and for safety put something behind the rear wheel and then start taking the bolts out of the pan and once the bolts are out use a large rubber hammer to get the pan loose do not use anything to pry the pan off and you see your oil pump
Posted on Feb 14, 2009
Anonymous
  • 54 Answers
SOURCE: High oil pressure and oil leak around oil filter seal.
It sounds like the check valve in the oil pump either has some trash in it or has gone bad. If it's a two wheel drive I don't remember the oil pan being that hard to get off. You can then drop the pickup and oil pump and soak them overnight in some parts cleaner. That may solve the problem, if there's trash in it. But if you're going to go through that much trouble, an oil pump shouldn't be that much I'd just replace it. So the problem doesn't come back. Good luck.
Posted on Jun 01, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Need to replace oil pump on 86 Chevy S-10 V6
No. Just remove the oil pan and the oil pump mounting bolt and the oil pickup tube nut and there is no need to lift the engine. Hope this helped and best wishes.
Posted on Aug 13, 2009
Larry Cowan
  • 274 Answers
SOURCE: Low oil pressure at idle, up tp 20psi under
You could have a blocked or broken oil pickup inside the sump or a broken spring in relief valve Think relief valve is on pump on those but not sure I'd be looking hard at pickup in sump
Posted on Jan 27, 2010
What type of oil does the Alto 4050 extra pressure cleaner use?
Nilfisk/Alto do their own pump oil. Go to their main web site and find a dealer or try ebay.
Feb 16, 2016 | Washing Machines
What type of oil for XL honda motor with Cat pump
the motor 30wt oil or 10- 30wt, the pump takes pump oil or 30wt
non-detergent, so the answer is no they don't take the same
Sep 14, 2014 | Honda Garden
I replaced the oil pump and rod and main bearings and i still have somewhat low oil pressure
How do you know that you have Low Oil Pressure?
Are you trusting the Gauge or putting an In-Line Gauge?
YOUR GM GAUGE CLUSTER is known to have BAD or DEFECTIVE STEPPER MOTORS...
If you put the In-line Gauge on and see that you have Good Pressure, then what you need to do is rebuild your Instrument Cluster.
MAKE SURE YOU USE X27.168 Stepper Motors... The Cheaper CHINEESE STEPPER MOTORS are black and are defective.
The X27.168 Stepper Motors are WHITE and will last for as long as you own the Truck.
Order 6 Stepper Motors and do them ALL at the same time or you can pay someone $95-$200 to rebuild it for you...
Apr 06, 2013 | 2004 Chevrolet Silverado
1984 chevrolet cavalier cs oil pressure warning light on but runs fine and oil level is ok. What could be the problem. Is there a sending unit that can be checked?
if the oil level is good and clean, and there is no noise in the motor then it will be the oil pressure switch that is bad and needs replacing.
Apr 25, 2011 | 1984 Chevrolet Cavalier Type 10
Dont get correct pressure. What type of oil do i
A loss of pressure on this type of washer is normally caused by failing water seals and check valves in the pump. You will need to replace both of these using a pump rebuild kit that will be available by contacting the manufacturer of your machine. The pump oil used will be 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Feb 28, 2011 | Black & Decker 1700 PSI Electric Pressure...
Can you remove the oil pan to change the oil pump without lifting the engine off the motor mounts? Also, if the pump is not bad, what gear drives the pump in the upper part of the engine and could it be...
No. You have to lift the engine. The distributor has a gear on it. this is what drives the oil pump. Most times 99% the bearings are worn out causing low oil pressure. I have replaced oil pumps, not because they were bad, but because someone wanted a high pressure pump. The first thing I would do if I suspected oil pressure problems is put a mechanical guage on the engine. If the oil pressure is normal then all you need to do is replace the oil sending unit. Of course if you knocking in the lower engine, then it would be bad bearings. Forget the pump. you need to replace the engine
Jan 22, 2011 | Ford Ranger Cars & Trucks
What type of oil does my black and decker chainsaw need
You can use SAE 30 weight motor oil or bar and chain oil. Press the bulb on the resevoir cap 2x before each cut making sure the saw is pointed down and to the right to let the gravity feed oiling system work properly.
Jan 05, 2011 | Black & Decker CCS818 Chain Saw
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Jun 01, 2009 | 1994 Jeep Cherokee
OIL PRESSURE GAUGE
I would start by replacing the oil pressure sensor. If that doesn't fix the problem, replace the oil pump. Its possible that the oil ports are partially clogged. If replacing sensor and pump do not fix the problem, you may want to try to flush the engine with an approved cleaner
May 18, 2009 | 2001 GMC Yukon
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
