I've never seen a lock like that was intended to be that way, but have made that mistake when the shaft that goes through the bolt portion of the deadbolt is square and is 90 degrees off in the square hole it goes through. If so remove two screws on the inside and take out assembly with the key hole, position key hole bottom, then put key side assembly with shaft through bolt portion of lock. Test the key to see if it locks and unlocks, maybe you need to position shaft 90 degrees to left or right to work, then put cover on inside house and the two screws.
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
SOURCE: The key still goes easily into the doorknob
can be easy as wd-40 squirt of oil. try that first... then on to more drastic measures
SOURCE: my keyless unit lock from the inside but when I
On this web page you will find installation/troubleshooting information and videos for the BE365, if you scroll down to the Electronic Security section.
If you are unable to find your own solution, please contact their Customer Support. here's the link:
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
SOURCE: schlage camelot key pad does
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
SOURCE: I have a Schlage that
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
