Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Shows code AO1, i drained the tub, restarted the machine, it worked for 2 minutes then the fault code returned.
Posted by mick carty on
  • mick carty
    mick carty May 19, 2016
    Hello, further to the above, I removed the right hand side panel from the machine - as ou stand facing it- I put some water in to the filter housing, about a litre, I see that there is a leak somewhere, there is seepage down on to the bottom panel of the machine - I cant say exactly from where this water seepage is starting, maybe somebody has experienced this and can point me towards a place in which to start checking for the source of this leak/seepage.
1 Related Answer
Anonymous
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
My Bosch WAE24367 washing machinet
check hose from the tub to the exit point you have a blockage
Jan 02, 2014 | Washing Machines
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Water remains in machine. Machine stops after a minute or so and diplays F11.
F11 means Drainage fault.
Water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause: Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause: Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause: Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause: Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
Hope this helps to solve it.
Jul 05, 2011 | Miele G2432SCISS Builtin Dishwasher
Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Remedy:
Cause:
Remedy:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
May 20, 2011 | Dishwashers
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Error code AO1
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
