Question about Music
When I record to waves it shows a play back but I dont hear any sound . Also when I add effects I dont hear them in the recording
Posted by Ralph Meier on
5 Related Answers
CRTN
Michael Fisher
  • 716 Answers
SOURCE: My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Posted on Jan 05, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Thing is that im recording a song. After
This is totally dependent on the software you are using to record.
Not knowing what you are using makes any response a wild guess.
IN GENERAL you must configure both the input and output device within the recording software you are using.
I use Sonar and one has to select the audio input and output device and tell the program which device is used for timing.
Posted on Aug 07, 2010
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: I am using this with Cubase AI 4 and my output is
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Posted on Nov 30, 2010
Fred Yearian
  • 5603 Answers
SOURCE: I can't hear sound from
In the "Sounds and Devices" of teh control panel under the Voice and also recording tabs amke sure the 2442 is selected instead of teh computer internal audiop system.
Posted on Feb 18, 2011
djredskyy
Joshua Staniels
  • 670 Answers
SOURCE: Good day gentlemen, If I had
check to see if your in monitor mode, seems like yout not
Posted on May 31, 2011
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
Latency during recording - makes playing in time impossible
I can totally relate, Tom. Good old multitrack recorders!
This may sound stupid, but you don't have like a slap back delay turned on by mistake, do you? Other than that, I'm afraid I'm not much help.
Mar 11, 2014 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Hello, I have a new black jack interface and Sony Acid studio on my PC with Windows XP. when I plug in an instrument, I can hear it in the headphones of the Blackjack, but not in the computer speakers. but...
Look at the setups for voice and audio in the Windows control panel, "Sounds and Devices". Make sure the devices are set to the sources and destinations you want... This is not automatic and is a pain when you are going back and forth from recording and playing...
Aug 19, 2011 | Mackie Onyx Blackjack Premium 2x2 USB...
I can't hear sound from my PC when I'm using the mixer. I plugged it in with the USB to the computer and tried to record using Cubase 4 LE. I seem to get sound in, but i can't hear any sounds from the...
Feb 18, 2011 | Behringer XENYX 2442FX Mixer
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Nov 06, 2008 | Boss Micro BR Digital Recorder
Music Logo
20 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
