Question about Emerson Televison & Video
My Emerson TV is stuck on number 1 channel how do I get it to go to other channels?
Posted by Teresa Smith on
  • Dorothy Jones Mar 15, 2021
    My emerson TV/DVD player say press and hold enter key for 3min on remote I don't have one
Joshua
  • 3 Answers
You have to reboot it or reset it again.
Posted on Mar 17, 2021
Bad Alice
    Problem Solver:
  • 6 Answers
Can you get to the main menu? If you can run set up and have the TV connected to a hi def antenna or cable TV box. I have seen on some TVs that running a channel scan set up with no available channels it will not store any channels. You have to have an incoming signal for the Television to find channels.
Posted on Mar 15, 2021
Richard Leister
    Habit-Forming:
    New Friend:
  • 70 Answers
Need to go into the menu look for the channel setup then check the skipped channels make sure channel 1 isn't the only Channel not checked also Look at Your scanned channels in the channel list how many do you have is channel 1 it ? you may need to rescan your channels . If the TV worked OK before but Not now try resetting Your TV , BUT do this last as You will need to reset all the parameters in Your initial setup as well as rescanning channels also the Volume may blast you after reset I always install a set of earphones in the Audio phone jack first . To reset the TV Unplug it from the back of the set wait 30-40 seconds reconnect the plug while holding the Power Button Reset Your Options and Settings then Rescan your channels Don't forget the volume and to unplug earphones Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Posted on May 18, 2016
5 Related Answers
Anonymous
  • 1476 Answers
SOURCE: chset stuck
You should have a button on your remote which says "display". Pushing that should toggle the ch number off. Hope this helps.
Posted on Jul 12, 2006
Anonymous
SOURCE: emerson color tv model EWT19B4
Get a universal remote so you can switch between the TV inputs.
Posted on Jan 06, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Posted on Jan 17, 2009
Anonymous
  • 6 Answers
SOURCE: emerson tv with no remote will not go to aux channel
Need the remote to go to the aux. The number for parts and service is on the back
Posted on May 13, 2009
Anonymous
  • 10594 Answers
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Posted on Jun 09, 2009
Got direct TV and had it cut off for a while. Went to go hook it back up and my Emerson TV will not come off of channel 1 and it needs to be on 4.
On TV go to menu /guide, then channel tuning / search. It should search thru all 999 or 9999 channels. Then it will go to the first channel finds when it is done, It wii take a few minutes. When its done you can put it on the channel you want.
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Stuck on a channel
Check and replace the main system memory IC. It is faulty.
1helpful
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
I can't change the channels on the tv with remote or on tv controls. The channel up button on the tv only goes to channel 1 or aux. I need channel 73 to use satellite service. We have changed batteries in...
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Emerson tv with no remote will not go to aux channel
2helpful
2answers
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
[email protected]
2answers
Chset stuck
Televison & Video Logo
Top Emerson Televison & Video Experts
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
