Question about Vizio Televison & Video
I have a Vizio model M651d-A2r that will not turn on and is unresponsive. As soon as I plug the tv in, the screen displays a horizontal line, a slope line, and a vertical strip of white (see picture).
Posted by Rolando Torres-Pagan on
magna buff
  • 3,828 Answers
It is still under warranty ?
One Year Parts & Labor; Free Lifetime Technical Support
ring tech support first
http://vizhdtv.com/contacting-vizio/
first sight of picture says cracked in behind screen
unresponsive is worse
if it doesnt show a picture at any time
looks replace a circuit board or the flat panel
cost of used/ referbished units
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-Smart/dp/B00CBQNB7K
Posted on May 18, 2016
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Screen displays Horizontal white lines
try adjusting the screen control down..if this has no control unit may have a bad video drive circuit or possible bad crt or fly back transformer ...just a wag
Posted on Feb 06, 2006
Pravin Gupta
  • 275 Answers
SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Posted on Sep 06, 2006
Anonymous
  • 45 Answers
SOURCE: Nopicture
No vertical deflection. Vertical output IC, caps.
Posted on Nov 25, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: RCA CRT TV thin white horizontal lines
Look for bad capacitors in the vertical deflection amp, and in the pin amp sections. This is common on most of these types of TV sets.
The caps tend to go high in ESR with age. It is best to use an ESR meter to find the bad caps. It will be a lot faster than workign out waveforms with a scope.
Wikipedia explanation about capacitor ESR:
http://en.wikipedia.org/wiki/Equivalent_series_resistance
Jerry G.
Posted on Apr 24, 2008
Anonymous
  • 84 Answers
SOURCE: 27" sharp has audio/no picture/ horizontal white line across screen?
bad vertical chip ic
Posted on Oct 19, 2008
Help fixing a Vizio M651d-A2R
Try a new tcon board and see if that helps.
Nov 21, 2017 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
A remote code to connect a sharp ht-cn300 surround system to a vizio remote control
0059,0027.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 23, 2014 | Televison & Video
What are the cisco cable box codes for vizio televisions
0281,0227,0294. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 05, 2014 | Vizio Brand Genuine smart TV remote XRT510...
Televison & Video Logo
327 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
