Question about Nintendo Wii Console
Wii console when we load any game the console says unable to read the disc refer to trouble shooting
Posted by dewick on
  • 5 more comments
  • denverdog Nov 20, 2007
    When disc is inserted it reads an error has occurred. Press eject button, remove disc, then turn the wii console off. We;ve done this repeatedly, unplugged also and started over, but it happens everytime we turn the console on. It does it with all of our wii games.
  • Anonymous Nov 21, 2007
    my wii won't let me load a game with out telling me i have a error and need to read the trouble shooting?
  • theo Deode Nov 21, 2007
    same as - console will not read disks
  • Anonymous Dec 01, 2007
    when we load games it says disc read error refer to troubleshooting guide
  • Anonymous May 22, 2008
    when ever i try to play on mario kart it always says trouble shoot, ive cleaned it and turned the wii off... when i turn it back on it always says trouble shoot. this disc came in a newly sealed package but it just isnt working
  • Anonymous Aug 05, 2008
    every disc i put in it says trouble shooting
  • Anonymous Mar 22, 2014
    When we put a disc in the game console it says " Will not read disc."
manageit
Did you try turning the disk over so the label shows on the opposite side. With the Wii you have to put them in upside down it seems.
Posted on Nov 30, 2007
  • rhonda winter Aug 08, 2013
    yes turned disc and used other discs but problem still shows
Anonymous
    Guru:
  • 1,463 Answers
Try here for more help http://wiiportal.nintendo-europe.com/6568.html
this might be of some guide .
riz.
Posted on Nov 18, 2007
Wii error message
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-48
Jun 08, 2009 | Nintendo Wii Console
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 04, 2008 | Nintendo Wii Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
    If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Aug 13, 2008 | Nintendo Wii Console
Rock Band / All Games "Unable to Read Disk"
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Aug 10, 2008 | Nintendo Wii Console
Unable to read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 05, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
169 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
