InFocus ScreenPlay 4805 Multimedia Projector Logo
C
Chris Gee Posted on May 16, 2016
When projector was working there was sudden loud bang, picture turned to black & white and then loud continuous whirring sound until shut down.
Tried to start up again but same noise and B&W picture so shut down again.
5 Related Answers
Anonymous
  • Posted on Mar 06, 2008
SOURCE: White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Anonymous
  • 472 Answers
  • Posted on Apr 11, 2008
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Anonymous
  • Posted on Nov 22, 2008
SOURCE: IN72 Projector problem
My understanding when we purchased our IN72 2 years ago is that there wasn't any additional benefit for Cable box using HDMI since the IN72 does not transmit audio so using component cables for cable was optimized enough. We have our DVD player connected via the HDMI only. Possibly the transmission from cable box through an HDMI is not compatible audio is confusing it? hard to say. Cable HD channels look awesome thru the compenent cables, the max for IN72 is 480i anyway.
We've got 35 ft cables for all 3 hdmi, compenent, and that vcr one too and it's worked great.
Anonymous
  • 4 Answers
  • Posted on Feb 04, 2009
SOURCE: Infocus ScreenPlay 4800 Loud Noise Problem
Sounds like the color wheel
projdoc
jasbo
  • 2239 Answers
  • Posted on Sep 03, 2009
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dellâ„¢.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dellâ„¢.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dellâ„¢.
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
My infocus 1503 works however once it is turned on the unit sounds as though it is ready to take off. The fan is very loud then after a few minutes it quiets down and then the fan becomes very loud again....
I own two of these projectors. You need to update the firmware to 1.03 which can be found on the infocus website. This solves the fan issues which also causes premature shutdown of the projector. Once you download the update, open it, there will be step by step instructions on how to do this procedure. I could not get this to work with Vista 64 so you might need to run this on XP or 7.
10helpful
2answers
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
1helpful
2answers
Will not turn on, red light flashing next to the menu button
if the fans don't turn on, they may be bad and needs replacing or rewired. if the fans turn on but not the lamp, the colorwheel may be bad (listen for a high-pitched whir when you switch it on. if no whir, replace the colorwheel). if the colorwheel is ok, replace the lamp.
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
6helpful
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
2answers
Loud noise when it is in DVD player, low brightness
I had a similar sounding problem. When I opened it up I found that the segmented color wheel was missing the clear segment of glass. I have not been successful finding parts for it.
Projector only displays Black and White / No color images.
The problem is the color wheel. It may have broken or motor stopped on clear. Either way the image will remain unchanged just without color. It will need to be sent in for service. Not an unusual problem for BENQ. I have had 3 that have come apart after making a loud whirring sound. Good luck getting someone with BENQ to help they are horrible when it comes to service. Buyers beware!!!
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
