Question about LG 55LN5710 55" LED TV 1920x1080, 120 Hz, HDTV
LG LED TV screen goes black. LG - 55LN5710-UI
First, it stayed on for about 20 minutes. Turning unit off/on fixed it. Now it goes black after 1 second. Audio remains on the whole time. What's the best way to diagnose what has failed?
Posted by Steve w an LG on
    Top Expert:
  • LG Master
  • 76,455 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on May 16, 2016
  • 2 more comments
  • Steve w an LG May 16, 2016
    Hello Knight, thanks for the prompt response. How do I tell if it is the main board or the Tcon board?
  • The Knight
    The Knight May 16, 2016
    Just try a hard reset. If the fault is with its main board, it should be rectified when you switch it ON after reset. If not, replace it.
  • The Knight
    There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.co...
    Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
    I had taken the TV down last night to pull the boards to get part numbers and see if I could at least find them if I needed them. So effectively, it had the hard reset you described. I reassembled the TV and hung it back on the wall. Came right on and has been on for over an hour now. Assuming it could be one of three things: the reset corrected it; I accidentally plugged the cable box into a different HDMI port; or, I now plugged the unit directly into a wall outlet versus a power strip. I did have a power strip partially trip a few times years ago making an old CRT unit go wacky. Wondering if that could be it. Will continue to monitor and also truly appreciate your help.
4 Related Answers
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: bottom half of screen goes black, what could be wrong?
Loose connetion on the Y-buffer board.
Posted on Apr 17, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Posted on Mar 25, 2012
gopakumarg43
  • 76455 Answers
SOURCE: Hello! My TV only shows picture for less than a second, then the screen goes black again. It's like a flashing. I replaced the led driver board. Bad Tcon? It has an LG Panel, LC500DUE SF R1 thanks!
It sounds to be a main digital board fault. Contact any service technician to make it confirm; before replacing the same.
Posted on Dec 24, 2015
dhopper122
  • 75 Answers
SOURCE: How do I determine if it's the LED Driver or the LED lights that are bad on my LG LED TV?
If it was the LEDs, then you should still have some working. My first thought would be the LED driver circuits.
Best of luck.
Posted on Feb 23, 2016
Re: LG 55LN5710 television screen saver How can I adjust the time before my screen saver comes on?
You need to go into the menu on the TV and adjust the screensaver/timeout settings.
Here is a link to the manual - https://www.lg.com/us/support-product/lg-55LN5710
Sep 16, 2018 | LG Computers & Internet
LG TV Model 55LN5710 LED backlight not working
Whatever be your plan, won't go. Contact the authorized service center for LG
Jan 30, 2017 | LG 55LN5710 55" LED TV 1920x1080, 120 Hz,...
LG 55LN5710 Smart TV Panel number LN54M550060V12
its normally an inverter fault that stops back light or the caps have failed also common problem
Apr 17, 2016 | Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
? 3:16
Dec 20, 2015 | LG Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
Dec 09, 2015 | LG 47LS4500
Tv on but no picture
How about the inverter board - it provides backlighting for the screen and when that goes you have often no picture at all.
Sep 16, 2015 | LG 55LN5710 55" LED TV 1920x1080, 120 Hz,...
LG 55LN5710 55" LED TV 1920x1080, 120 Hz, HDTV Logo
823 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
