Question about Ricoh Office Equipment & Supplies
Ricoh 7500 photo copier Error SC 552 how to reset it ?
    New Friend:
  • 49 Answers
Yellow cancel
107
Hold down red cancel
Select system/copy sp
On keypad type in 7807#
Tap execute On the screen
Switch machine of and on again
Machine should be good to use, unless you have a actual problem then the machine will go back to error state.
Posted on Jun 04, 2016
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Posted on May 20, 2008
Anonymous
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
Anonymous
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: RICOH LASER AP2610N - error - SC 998
Normal 0 Could have a corrupt driver.
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
gggg
  • 904 Answers
SOURCE: how can i solve error code sc:302 in ricoh Aficio
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Posted on Aug 26, 2010
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
Feb 06, 2018 | Ricoh Office Equipment & Supplies
How to clear ricoh MP 2001 sc 552 errors code
http://terraofficesolutions.com/forum/index.php?topic=7.0
Quoting from the link shown:
Ricoh Error Code 552, SC552 Fix - Printer, Copier, Fax Machine « on: September 20, 2012, 10:37:12 pm »
This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds.
May 08, 2017 | Ricoh Office Equipment & Supplies
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
I HAVE A PROBLEM(errore sc-552) WITH MY COPIER Ricoh Aficio 2027 All-In-One Laser Printer
found this solution on line -Ricoh Copier Error Code SC 552 is Fusing thermistor error 2 problem
1. Fusing lamp is not connected angry.gif:(" title="Angry"> (reconnect it)
2. bent or is bad [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry"> (replace it)
3. Thermistor position incorrect [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry">
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
.... if this is not working, you might need new Fuser Thermistor ... go to Copier Parts Outlet.com find your copier, order your copier thermistor .... they have YouTube videos how to replace them too ...
Try this Video first:
youtube.com/watch?v=2S_jH3MOwr4
Jan 14, 2014 | Computers & Internet
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
1,142 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
