SOURCE: Shredder suddenly runs only in reverse
Do you hear the motor moving in both directions? I just had the same problem with mine. On mine, you can hear the motor moving in both directions but it would only move the shredder teeth in reverse and the teeth would not move going forward. I took the unit apart and found out that the gear right next to the motor shaft was rounded out in the middle. The solution would be to get a new gear or gears if you can get them. Make sure you inspect all the gears to see if there is a lot of play. You might have to replace more than 1 gear. What I did on mine, was take a brass tubing that was just a little larger than the shaft, drill out the center of the bad gear and press the tubing into the center of the bad gear. This took up the extra play and my Tech Solution TS8000 is working again. Hope this helps. If you have any other questions, feel free to email me at [email protected]
Did you check out this thread?
http://www.fixya.com/support/t135563-shredder_suddenly_runs_only_in_reverse
SOURCE: techsolutions ts4500 quit running while shredding and won' start
I threw it in the trash and purchsed a big scissors.
SOURCE: shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
