mystery system -generic answer --if oil check and test or clean fire sensor fuel delivery fan /fan sensors high limit sensor flue is clear ---gas same as above but add thermocouple and gas valve .....and blinking red light means shut down for failing to start or operate correctly ---do a search for your manual or normally its with unit and look up trouble shooting for reset or notify a licensed service person / company
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing
If I attempt to turn it back on the fan revs up and then shuts off
15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
The Unit is Shutting itself down to protect itself from more damage, the light is blinking to let you know there is a problem, the problem could be a number of things, check the horizontal output transistor. It's a good Place to start for shut down problems
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
