Question about Lenovo Computers & Internet
Can I install this on my lenovo computer running windows 8
Posted by Jeanie Feltman on
  • Jeanie Feltman
    Jeanie Feltman May 15, 2016
    I am trying to install Print Master Gold 8.0
Donald Ayers-Marsh
  • 1,389 Answers
Google<i> (software name) installation requirements, </i>or tell us what software you are trying to install, as Lenovo does not produce software.
Your comment (sorry, deleted with my original post so that I could post a link) indicates you have already tried and failed to install Print Master Gold 8.0. When I google install requirements it only lists up to Win7. But you can install almost any software on Win8 and 10 using compatibility mode. Here are the instructions from Microsoft.
Make older programs compatible with this version of Windows Windows Help
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on May 15, 2016
Speaker no sound
Your are probably missing a driver. Or a wrong driver is installed on your pc click on the start bottom in your windows and search for device manager if you have a tab called other devices in device manager you are missing a driver if that is the case run lenovo system update on your machine and it will find and install the right driver for you.
Dec 17, 2015 | Lenovo Computers & Internet
Factory reset my lenovo y510 when forgotwindows password
If its running Windows 8 the login might be linked to a microsoft account. from another computer login or reset your password to that account and try logging back into the laptop (as long as it has an active internet connection) If its windows 7 or older you might need to find a Live repair disk (ERD or Hiron's boot cd or something along those lines that has a password recovery tool incorperated)
Worst case you would need the windows installation disk or restore disks that came with the laptop
Oct 05, 2014 | Lenovo IdeaPad Y510 Notebook
When I update Windows 8 to 8.1 Lenovo Z500 Series Laptop than My computer Brightness is decrease?Please give me solution
Try this:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
May 13, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Osd not working in lenovo g480
Cusious, windows 8 or any other should not avoid the monitor OSD
I would suggest trying the monitor on another source and see if still OSD not functionning. then if it is the case the OSD menu button can be stuck (does not give the signal)
try to work the thing from there.
Jan 03, 2014 | Lenovo Computers & Internet
My lenova ideapad has been running via my linksys wireless router. today it dropped it and will not locate it. the wireless is functioning on my other devices but i can connect my computer only via ca
Update the wireless card driver. You can get the update in the website of your computer's manufacturer. Since you can't access the internet with your lenovo, use the other computer and save the update file. Put it in a USB drive and install it to your defective computer.
After installing the update, the internet should be back. If it's fixed, I suggest that you install RadarSync to keep the drivers updated so that you won't get the same problem in the future.
One more possible reason of this issue is your firewall settings. Try checking it, it might be blocking the wireless connection.
David
Apr 05, 2013 | Lenovo 3000 G530 Notebook
Can't load updated ThinkCentre BIOS
Try right clicking the EXE and running it as an administrator.
Feb 14, 2013 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
I WANT TO INSTALL WINDOWS 8 ON MY IBM R60 BUT THERE IS A RISK OF LOOSING DRIVERS . I DONT HAVE DRIVERS CD SO PLEASE TELL ME HOW AND FROM WHRE I CAN DOWNLOAD THE DRIVERS FOR MY IBM
Use the Windows 7 Upgrade Advisor
Before scanning your PC with the Windows 7 Upgrade Advisor, be sure to plug in and turn on any USB devices or other devices, such as printers, external hard disks, and scanners, that you regularly use with the PC you're checking.
Download the Windows 7 Upgrade Advisor
Sep 18, 2012 | IBM ThinkPad R60 Notebook
WINDOWS 8 PREVIEW INSTALLED ON LENOVO IDEAPAD AND IS NOT WORKING PROPERLY SO TRYED TO RECOVER TO WINDOWS 7 BUT NOT WROKING!!!!
You will need a separate recovery disk. Sounds like the recovery partition of your HDD got overwritten. Maybe you can create a windows WinPE (microsoft docs) and use that. This says what to do once you have a recovery disk.
https://pureinfotech.com/how-to-uninstall-windows-8-developer-preview-and-restore-windows-7-step-by-step/
Sep 25, 2017 | Lenovo IdeaPad Computers & Internet
Hi,haw to instal System Suite 10 to Lenovo
If your Ideapad is the U3 or U5 version just pop in the disk that you have bought and it will autostart.
If your Ideapad is the U1 or U3 (so it doesn't have optical unit) and you have bought the boxed version then your only option is to copy the content of the disk to a USB stick and run the setup from there.
Mar 20, 2010 | Avanquest System Suite 8: Windows
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
