Hej, i cannot find wifi router in my wifi list, seems the router is not emmitting wifi signals , and i cant even see the wireless light turned on , which shows that router's wifi is working. need to know , is there any way to turn on wifi on the router.
Please make sure WIFI enabled in settings
Check Broadcast SSID enabled in router
also you can factory reset router to fix it.
if still same issuce contact -https://routerlogins.net/routerlogin-net/
To turn on wifi connect the power cord from your routers to the power outlet box then connect a computer to one of the rg45 or LAN of your router check the manual of your router for setting by using your browser with the ip specify on your router's manual eje: http:\\192.196.0.1:80 on your browser it dependent the manufacture of your router. And locate it the right setting or power ciacle the router by turning it off or desconnecting from the out let for 5 minute and make sure your computers have wireless on look by the button sing of wireles on your computer hold it and let go until you see the wireless light
