I have fitted a new pressure switch and there is a V shaped piece of metal and I don't know how it fits in?
SOURCE: karcher hd 5 11/c pressure washer no pressure
Your problem is simply a worn bypass valve on its awy out. It still works enough for mains pressure but can not pressurise when drawing water.
SOURCE: where does small spring fit
Most Karcher guns I have worked on have had a spring behind valve between hose pipe inside gun.
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
SOURCE: Karcher K6.50 possible pressure switch problem?
sounds like the unloader is stuck onthe machine which pushes against the micro switch.
follow the instructions for a parts diagram.
www.karcher.com
click on europe
then click on international
go to service and spare parts will open, click spare parts
then put in k6.50m on there will be another number on your machine 8 digit , easy way to find your machine, could 10 different models
SOURCE: Where can purchase pressure fit axle nuts for my
These are available at Lowe's/similar.
Best regards, --W/D--
