Question about Chevrolet 2012 Chevrolet Sonic 2LT
Engine bolt torques
Head bolts, valve cover bolts, cam gear bolts, oil pan bolts, timing belt tensioner bolt, intake manifold bolts, exhaust manifold bolts
Posted by Roy Martinez on
L Pfaff
    Top Expert:
  • Chevrolet Master
  • 11,573 Answers
Roy you really should get yourself a manual, Google search your year, make and model# manual. good Luck.
Posted on May 14, 2016
Testimonial: "What I really need is a program that updates this kind of stuff. I've been doing this professionally for almost 40 years and it's crazy how even torquing bolts has changed"
  • L Pfaff
    L Pfaff May 14, 2016
    Roy, I here you! It has gone from torque in in.lbs. and ft lbs. to newton meters and now Degrees, sometime in 4 steps, It drives me crazy too. Sorry I could not help more, just do not want to give you bad info., Even though it says Chevrolet master beside my name, it is the fixya program that does this. I do work on all different makes and models in the past and not a master of any with all the changes every couple years, who can afford to keep up. Good Luck, have a good day.
Julie Clark
    Sergeant:
  • 266 Answers
Google it, using your year, make and model and the word torque.
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
I NEED TIMING CHAIN DIAGRAM FOR VQ20 NISSAN SERFIRO 1999
Instructions
  1. Remove Your Timing Chain
    • 1 Check your owner's manual for the recommended mileage for replacing your timing chain. Replacement for a Nissan Altima is 60,000 miles.
    • 2 Locate the timing chain. Replace it if the automatic chain adjuster (also known as the tensioner) is damaged or worn.
    • 3 Drain the cooling system and disengage the negative battery cable. Undo the spark plug wires and set the No. 1 piston at "Top Dead Center" (TDC) of the compression stroke.
    • 4 Disconnect the engine undercover, vacuum and fuel hoses, harness and connectors, drive belts, power steering reservoir, alternator and bracket, upper radiator hose, air duct, front exhaust tube, intake manifold collector supports, collector and exhaust manifold and the distributor.
    • 5 Prop up the oil pan and take out the front engine mounting, the valve cover, camshaft sprockets, cam bearing caps, camshafts, cylinder head bolts (reverse the installation order), cam sprocket cover, upper chain tensioner, chain guides and chain, idler sprocket bolt, cylinder head, intake manifold and cylinder head gasket and the steel oil pan.
    • 6 Place a steel cutter between the steel and aluminum oil pans. Slip the cutter around the oil pan's edge. Disengage the steel oil pan, baffle plate, oil strainer and the front tube.
    • 7 Secure the car on jack stands and place a seal cutter in between the oil pan and cylinder block. Slip the cutter around the oil pan's edge.
    Install Your Timing Chain
    • 8 Reconnect the crankshaft sprocket, oil pump drive spacer, idler sprocket and lower timing chain. Position the lower timing chain on the sprockets and line up the mating marks.
    • 9 Rub on an unbroken bead of liquid gasket and put in a new front cover and oil seal. Secure the bolt at 105 to 112 foot pounds (142 to 152 Nm).
    • 10 Eliminate any old material from the pan and cylinder block mounting surfaces. Rub on a 3.5 to 4.5mm bead of liquid gasket over the oil pan and cylinder block.
    • 11 Attach the upper timing chain to the idler sprockets and secure the cylinder head bolts.
    • 12 Refill the cooling system and add clean oil in the engine.
    • 13 Hook up the negative battery cable and any other disconnected parts or items. Start the engine and look for leaks.
Tips & Warnings
  • Procedures for replacing timing chains in Nissan Altimas vary slightly depending on engine size.
  • Make sure the new timing chain matches the chain you are removing.
Jun 12, 2012 | Cars & Trucks
Need timing gear marks for 2004 Kia Sadona 3.5L engine
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes.
    Kia_Sedona_2002-2006
    Timing Chain, Sprockets, Front Cover & Seal
    Print
    3.8L Engine
    3. Remove the engine from the vehicle.
    4. Remove the drive belt. Remove the power steering pump. Remove the air conditioning compressor.
    5. Remove the alternator. Remove the drive belt idler. Remove the drive belt tensioner. Remove the water pump pulley. Remove the intake manifold.
    6. Remove the connector bracket from the left cylinder head cover. Disconnect the right ignition coil connector, condenser connector and remove the bracket.
    7. Remove the left cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    8. Remove the right cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    9. Set the No. 1 cylinder to TDC on the compression stroke. Turn the crankshaft pulley and align its groove with the timing mark T of the lower timing chain cover.
    10. Check that the mark of the camshaft timing sprockets are in straight line positioning on the cylinder head surface. If not rotate the crankshaft 360 degrees. Do not rotate the engine counterclockwise.
    11. Remove the oil pan. Remove the crankshaft damper pulley. Remove the timing chain cover.
      NOTE Be careful not to damage the contact surfaces of the cylinder block, cylinder head and timing chain cover. Before removing the timing chain, mark the right and left timing chains with an identification mark based on the location of the sprocket because the identification mark on the chain for TDC can be erased.
    12. After compressing the timing chain tensioner, install a set pin. Remove the right cam to cam guide. Remove the right timing chain auto tensioner and timing chain tensioner arm.
    13. Remove the oil pump chain cover. Remove the oil pump chain tensioner assembly. Remove the oil pump chain guide. Remove the right timing chain.
    14. Remove the right timing chain guide. Remove the oil pump chain sprocket and oil pump chain. Remove the crankshaft sprocket, oil pump and camshaft drive gear.
    15. Remove the left cam to cam guide. Remove the left timing chain auto tensioner and timing chain tensioner arm. Remove the left timing chain.
    16. Remove the left timing chain guide. Remove the crankshaft sprocket and left camshaft drive. Remove the tensioner adapter assembly.
      Fig. Timing chain and related components-3.8L Engine
    To install:
    1. Check the camshaft and crankshaft sprockets for wear and damage, replace as required.
    2. Inspect the tensioner arm and chain guide for wear and damage, replace as required.
    3. Check that the tensioner pin moves smoothly when the ratchet pawl is released with a thin rod.
    4. The key of the crankshaft should be aligned with the timing mark of the timing chain cover. This indicates that the piston is at TDC on the compression stroke.
    5. Install the tensioner adapter assembly. Install the crankshaft sprocket and left camshaft drive.
    6. Install the left timing chain guide and torque the retaining bolts 14-18 ft. lbs.
    7. Install the left timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, timing chain guide, exhaust camshaft sprocket, intake camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
    8. Install the left timing chain tensioner arm and torque the retaining bolts 14-16 ft. lbs.
    9. Install the left timing chain tensioner and torque the retaining bolts 7-9 ft. lbs.
    10. Install the left cam to cam guide and torque the retaining bolts 7-9 ft. lbs.
    11. Install the crankshaft sprocket, oil pump and right camshaft drive.
    12. Install the oil pump chain and oil pump sprocket. Torque the retaining bolt to 14-16 ft. lbs.
    13. Install the right timing chain guide. Torque the retaining bolts to 14-18 ft. lbs.
    14. Install the right timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, intake camshaft sprocket, exhaust camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
    15. Install the right timing chain tensioner arm. Torque the retaining bolts to 14-17 ft. lbs.
    16. Install the right timing chain auto tensioner. Torque the retaining bolts to 7-9 ft. lbs.
    17. Install the right cam to cam guide and torque the retaining bolts to 7-9 ft. lbs.
    18. Install the oil pump chain guide. Torque the retaining bolts to 7-9 ft. lbs.
    19. Install the oil pump tensioner assembly. Torque the retaining bolts to 7-9 ft. lbs.
    20. Pull out the pins on both the left and right hydraulic tensioners. Install the oil pump chain cover.
    21. Rotate the crankshaft two revolutions in the clockwise direction. Confirm the timing mark. Be sure to rotate the crankshaft in the clockwise direction.
    22. Apply sealant on the chain cover and on the cylinder head, cylinder block, and lower oil pan. Be sure these parts are free of engine oil and dirt.
      NOTE Before assembling the timing chain cover, the liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Sealant application (1 inch bead width)-3.8L Engine
    23. Apply sealant on the chain cover.
      NOTE The liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Timing cover sealant application-3.8L Engine
    24. Install a new gasket to the timing case cover.
      NOTE It is important that the dowel pins on the cylinder block and holes on the timing chain cover should be used as a reference in order to assemble the timing chain cover in the correct position.
      Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
    25. Install the timing chain cover. Torque the retaining bolts in the proper sequence and to specification. The engine should not be started for at least thirty minutes after timing chain cover assembly.
      Fig. Timing cover bolt torque sequence and specification-3.8L Engine
    26. Install the timing case cover oil seal.
    27. Continue the installation in the reverse order of the removal procedure.
May 19, 2012 | 2004 Kia Sedona
Could you advise what are the cylinder head bolt tension settings for hyundai lantra j5. Could you email me back on [email protected] Thanks
let me see if i can get some info 4 you.
edit
REMOVAL
1. Drain the coolant and disconnect the upper radiator hose.
2. Remove the breather hose (between the air cleaner and the head cover).
3. Remove the air-intake hose.
4. Remove the vacuum hose, fuel hose and coolant hose.
5. Remove the cables from the spark plugs. The cables should be removed by holding the boot portion.
6. Remove the ignition coil.
7. Remove the power steering oil pump and bracket.
8. Remove the intake manifold.
9. Remove the heat protector and exhaust manifold assembly.
10. Remove the coolant pump pulley and the crankshaft pulley.
11. Remove the timing belt cover.
12. Remove the timing belt tensioner pulley.
13. Remove the timing belt.
14. Remove the head cover.
15. Remove the cylinder head assembly. The cylinder head bolts should be removed by using Special Tool, Cylinder Head Bolt Wrench (09221-32001) or equivalent, in the sequence as shown in the illustration in two or three steps.
16. Remove the gasket pieces from the cylinder block top surface and cylinder head bottom surface. NOTE: Make sure that the gasket pieces do not fall in the engine.
INSTALLATION
1. Clean all gasket surfaces of the cylinder block and the cylinder head.
2. Install a new cylinder head gasket onto the cylinder head assembly. Apply sealant to the gasket and do not reuse the old cylinder head gasket.
3. Install the cylinder head bolts. Starting at top center, tighten all cylinder head bolts in sequence as shown in illustration, using the Cylinder Head Bolt Wrench (09221 - 32001) or equivalent. Repeat the procedure, re-tightening all cylinder head bolt to the specified torque. (torque spec is Cold Engine 105-115 Nm (76-83 ft lb) )
4. Install the timing belt tensioner pulley.
5. Install the timing belt on the camshaft sprocket, making sure that the tension side is tightened by turning the camshaft sprocket in reverse, all timing marks are in alignment.
6. Adjust the timing according to "Timing Belt"
7. Install the rocker cover and tighten the bolts to the specified torque. Tightening torque: Rocker cover belt:
2.5-3.5 Nm (25-35 kg.cm, 2-3 ft. lbs.)
8. Install the timing belt cover.
9. Install the new intake manifold gasket and the intake manifold. Tighten the nuts and bolts to the specified torque.
10. Install the new exhaust manifold gasket and the exhaust manifold. Tighten the exhaust manifold attaching nuts to the specified torque.
11. Install the surge tank and tighten the nuts bolts to the specified torque.
12. Install the power steering oil pump and bracket.
13. Install the ignition coil.
14. Install the air intake hose.
15. Connect the vacuum hose, fuel hose and water hose.
16. Install breather hose.
Jun 08, 2011 | Hyundai Elantra Cars & Trucks
Need cylinder head torque specifications 2004 hyundai elantra
Dec 22, 2010 | 2004 Hyundai Elantra
Need to change timing chain. do i need to remove the head?
Check the vehicle manual for recommended mileage for replacing the timing chain.Locate the timing chain,you will need to replace it if the automatic chain adjuster "also known as the tensioner " is damage or worn.Drain the cooling system and disengage the negative battery cable.Undo the spark plug wires and set the No.1 piston at Top Dead Center ( TDC ) of the compression stroke. Disconnect the engine undercover,vacuum and fuel hoses,harness and connectors,drive belts, power steering reservoir,alternator and bracelet,upper radiator hose and,air doct,front exhaust tube,intake manifold collector supports,collector and exhaust manifold and distributor.Prop up the oil can and take out the front engine mounting,the valve cover and camshaft sprockets,cam bearing caps and camshafts,cylinder head bolts, cam sprocket cover,upper chain tensioner,chain guide and the chain,idler sprocket bolt,cylinder head,intake manifold and cylinder head gasket and the steel oil pan. Place a steel cutter between the steel and aluminum oil pans.Slip the cutter around the the edge of the oil pan and disengage the steel oil pan,baffle plate,oil strainer and front tube. Secure the vehicle on jack stands and place a seal cutter between the oil pan and the cylinder block,slip the cutter around the edge of the oil pan.
Aug 15, 2010 | 1997 Nissan Pickup
Cylinderhead torque stc.
Cylinder Head Removal & Installation SOHC To Remove:
  1. Relieve fuel system pressure.
  3. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  4. Loosen lock bolt on tensioner.
  5. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt.
  6. Remove timing belt from camshaft pulley.
  7. Disconnect battery negative cable.
  8. Remove 3 bolts that secure accelerator cable and air intake hose to cylinder head cover.
  9. Detach accelerator cable and place off to side.
  10. Remove the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
    • Vacuum hose from air intake hose
  11. Disconnect mass air flow sensor electrical connector.
  12. Remove air intake hose.
  13. Remove PCV valve from cylinder head cover.
  14. Remove ISC air hose from idle speed actuator.
  15. Remove air hose from behind intake manifold.
  16. Remove 2 screws from high tension wire protectors.
  17. Detach wire loom from holder at rear of cylinder head cover.
  18. Detach vacuum tube at rear of cylinder head cover.
  20. Remove 7 cylinder head cover bolts.
  21. Remove cylinder head cover and gasket.
  22. Disconnect 2 ignition coil electrical connectors.
  23. Disconnect 2 fuel injection electrical connectors at rear of cylinder head.
  24. Disconnect the following electrical connectors;
    • Oxygen sensor
    • Throttle position sensor
    • Idle speed actuator
    • Oil pressure switch
    • EGR vacuum solenoid valve at intake manifold
  25. Disconnect heater hose from elbow.
  26. Disconnect brake booster vacuum hose and cruise control vacuum hose from surge tank.
  27. Detach wire harness from rear of cylinder head.
  28. Disconnect purge control solenoid vacuum hose from intake manifold.
  29. Disconnect fuel hose from fuel connector assembly.
  30. Remove grounding bracket.
  31. Remove 4 bolts and intake manifold bracket.
  32. Remove starter.
  33. Detach water bypass hose from bypass pipe.
  34. Disconnect water hoses from oil cooler.
  35. Disconnect fuel hose from fuel pipe.
  36. Remove exhaust manifold heat shield.
  37. Remove exhaust flange nuts and front exhaust bracket bolt.
  38. Lower exhaust system. Cylinder head bolt loosening sequence kia-03-20-7050.gif
  39. Loosen cylinder head bolts in 3 steps in proper sequence.
  40. Remove cylinder head bolts and washers.
  41. Remove cylinder head, intake manifold and exhaust manifold as an assembly.
To Install:
  1. Install NEW cylinder head gasket.
  2. Install cylinder head, intake manifold and exhaust manifold as an assembly.
  3. Tighten cylinder head bolts in 3 steps in reverse sequence that was used during removal. Tighten bolts to 62 ft lb (84 Nm).
  4. Install front exhaust bracket bolt. Tighten bolt to 20 ft lb (27 Nm).
  5. Install NEW lower exhaust flange gasket and 3 nuts. Tighten nuts to 24 ft lb (31 Nm).
  6. Install exhaust manifold heat shield. Tighten nuts to 35 in lb (4 Nm).
  7. Connect fuel hose to pipe.
  8. Connect 2 hoses to oil cooler.
  9. Attach water bypass hose to bypass pipe.
  10. Install starter and bolts. Tighten bolts to 34 ft lb (46 Nm).
  11. Install intake manifolds bracket and 4 bolts. Tighten bolts to 32 ft lb (45 Nm).
  12. Install grounding bracket.
  13. Connect fuel hose to fuel connector assembly.
  14. Connect the following electrical connectors;
    • Oxygen sensor
  15. Connect purge control solenoid vacuum hose to intake manifold.
  16. Attach wire harness from rear of cylinder head.
  17. Connect brake booster vacuum hose and cruise control vacuum hose to surge tank.
  18. Connect heater hose to elbow.
  19. Connect 2 fuel injection electrical connectors at rear of cylinder head.
  20. Connect 2 ignition coil electrical connectors.
  21. Install cylinder head cover.
  22. Install 7 cylinder head cover bolts. Tighten bolts to 60 in lb (7 Nm).
  23. Install vacuum pipe and 2 bolts at rear of cylinder head cover. Tighten bolts to 60 in lb (7 Nm).
  24. Connect vacuum tube to pipe.
  25. Connect loom holder to rear of cylinder head cover.
  26. Install 2 screws to high tension wire protectors.
  27. Install air hose to behind intake manifold.
  28. Install ISC air hose to idle speed actuator.
  29. Install PCV valve to cylinder head cover.
  30. Install air intake hose.
  31. Connect mass air flow sensor electrical connector.
  32. Install the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
  33. Attach accelerator cable.
  34. Install 3 bolts that secure accelerator cable and air intake hose to cylinder head cover. Timing belt pulley timing marks kia-03-20-7035.gif
    NOTE: Timing belt pulley timing mark and timing mark must be aligned.
    NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  35. Install timing belt.
  36. Install timing belt cover.
  37. Pressurize fuel system.
  38. Start engine and check ignition timing.
Jul 11, 2010 | 1999 Kia Sportage
I need the head bolt torque specification for a 2005 aveo
install:
  1. The cylinder head should be cleaned and inspected prior to installation.
  2. Lightly oil all bolt and stud bolt threads before installation.
  3. Clean all gasket mating surfaces thoroughly.
  4. Install a new head gasket on the cylinder block. WARNING Always use new cylinder head bolts when installing the cylinder head or damage to the engine may occur.
  5. Install the cylinder head on the cylinder block.
  6. Tighten the cylinder head bolts in reverse of the removal sequence. Tighten the 2004 cylinder head bolts to 18 ft. lbs. (25 Nm). Tighten an additional 70°, plus 70°, plus another 50°. Tighten 2005 bolts to 18 ft. lbs. (25 Nm). Tighten an additional 60°, plus 60°, plus another 10°.
  7. Install the right engine mount. Tighten the engine mount attaching bolts to 22 ft. lbs. (30 Nm).
  8. Install or connect the following:
    • Intake manifold
    • Intake manifold support bracket. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Throttle cable
    • Surge tank coolant hose
    • Heater hose to cylinder head
    • Fuel feed line at the fuel rail
    • All vacuum hoses
    • Exhaust manifold
    • Rear timing belt cover
    • Timing belt tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Idler pulley. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Intake and exhaust camshaft gears. Tighten the bolts to 49 ft. lbs. (68 Nm).
  9. Apply a small amount of gasket sealant to the corners of the front camshaft caps and the top of the rear camshaft cover-to-cylinder head seal.
  10. Install the valve cover using a new gasket
  11. Align the timing marks on the camshaft gears.
  12. Align the mark on the crankshaft gear with the notch at the bottom of the rear timing belt cover.
  13. Install the timing belt and rotate the water pump clockwise to apply tension to the timing belt.
  14. Tighten the water pump bolts to 89 inch lbs. (10 Nm).
  15. Adjust the timing belt tension.
  16. Install or connect the following:
    • Spark plug wires
    • Upper and lower timing belt coversCrankshaft pulley. Tighten the bolt to 70 ft. lbs. (95 Nm), plus an additional 30°, then another 15°.
    • Accessory drive belt
    • Air cleaner housing
    • Radiator hoses
    • Front splash shield
    • Right front wheel
    • Coolant temperature sensor
    • Fuel feed line from fuel rail
    • IAT sensor
    • Intake manifold pressure sensor
    • DIS coil connector
    • Fuel injector connectors
    • ECM ground terminal
    • Negative battery cable
  17. Fill the engine with oil and coolant.
Apr 02, 2010 | 2005 Chevrolet Aveo
Timing Belt Tensioner bolt broken off.
You may have a serious problem (timing belt tensioner). This tensioner keeps the belt 'taut' so it won't jump time. Daewoo engines are 'interferrence' engines (this means if the valve timing is 'off' (out of syncronization) you can damage/bend the valves in the head -- valve timing (timing belt ensures this). The solution is to take the vehicle into the shop and have it diagnosed to be sure/to know if any damage has occured -- if none, replace the tensioner... it's pretty simple to do, if you have the service manual.
May 26, 2009 | 2000 Daewoo Nubira
2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Sep 08, 2008 | 2005 Hyundai Tucson
Chevrolet 2012 Chevrolet Sonic 2LT Logo
587 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
gludwick2
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
