Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
One of the baffles looks like a paddle came off from the inside of the tub
I found 2 plastic clips but no screws
Posted by Dennis White on
3 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Coin stuck in the tub baffle
its a little tricky but can be done. Can you remove the top panel of your washer?? 3 *****s along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless ***** in from behind to hold baffle in place,ifso remve the ***** and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall heres a replacement number for hte baffle 8182233, incase youbreak it youll need to replace
Posted on Mar 10, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Replacing a baffle
this is a good one. easy too, once you see how its done, youll need to remove th top cover 3 screw across the top of unit, after removing the top look directly in the middle of the outer tub, youll see a black hose coming from the dispensor and entering diretcly into the top of tub. remove the hose from th tub( it will squeeze right out0. after that youll be able to see the stainless steel inner basket through the hole, youll have to spin the tub from the inside unitl the baffle is a t the top and oyu will see the screw hole will line right up,careful not to drop screw and remember to reinstall that hose or you get a flood
Posted on Mar 19, 2009
fixrguy
  • 415 Answers
SOURCE: Replacing a part on a Kenmore Washer HE 3T
you shouldn't have to get from the backside the screw is at the rear of the baffle once you remove the screw the tabs slide and lock into slots push and pull and just reverse the process when installing the new one
Posted on Sep 03, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
The bar things inside the dryer drum (there are three of them) one has come almost all the way off. and one is loose. looks like its screwed from the other side.. cant figure out how to get inside. it...
Unplug the dryer. Open the door and remove a total of 4 screws, 2 on each side of the door opening. Two screws each hold a clip in place and the other two hold the dorr hinges. When you remove the screws on the door hinge, it shouldn't fall off, but be prepared for it to do just that. The door should come off by lifting the hinges upward and pulling the door away. The remaining part of the front panel is held on by 2 clips located toward the top sides of the u-shaped front panel. Pull the panel forward to release the clips and lift the panel upward to clear the two tabs and slots on the bottom. On each side of the cabinet, there is a blackish colored metal bracket that holds the top in place. Remove the fasteners that holds these brackets and remove the brackets by sliding them upward and away. The top should now lift up. You now have access to the fasteners that hold the baffles onto the drum. If , for some reason, you should want to remove the baffles, carefully note the different sizes of the baffles and what order they came off.
Here is the parts list for the drum of your dryer:
http://www.repairclinic.com/Maytag-Model-MDE3500AYW-ID-508609-Drum-Or-Tub-And-Related-Parts
Good luck from Detroit, MI.
Jul 18, 2011 | Maytag Dryers
Paddle came off inside dryer drum I need to open the top so I can put more screws in
remove 4 screws around the door perimeter,remove door,then the front panel will pull off towards you then remove 2 hex headed screws just under where the top and front covers meet,then you can raise the top to replace baffle/paddle screws
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How to repair paddle inside drum paddle that fell off
To replace this "paddle" (It's callde a baffle), you'll need to access the outside of the tumbler (drum), by lifting the top.
Begin by removing the door. Remove the two hinge screws. You will then be able to rock the door and hinge out of the slot in the front panel. Next, remove the cover plates just opposite the hinges.
Now you can pull the front panel off the retaining clips and rock it downward, away from the rest of the cabinet. Once it clears the top, you can lift it off the bottom hooks. Just set it aside.
You will now see two screws (hex-head, 5/16 inch), just under the corners of the dryer top. Remove them and rotate the brackets that hook into the top. Removing the brackets will allow you to now swing the top upwards to expose the tumbler.
Just turn the tumbler until you can see the screw holes for the babble holding screws. You may get lucky and find the three baffle screws in the bottom of the cabinet. Re-install, check the others, and re-assemble the dryer in reverse order, and you're done!
Dec 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How do I get change out of the washer? It went
I think you are talking about the three tub baffles that are attached to the inner tub. You can remove the baffles, usually one or two screws hold these into the tub. If it only has one screw then the opposite end is clipped into the tub. Most coins however get flushed down into the drain pump filter. We call this a coin catcher as that is what it is designed to do. Remove the front bottom panel, 3 to 4 screws on the bottom. Put a towel down under the pump to catch about a half gallon of water. There is a large round plastic screw that you unscrew from the pump assembly. The screw is three to 4 inches in diameter and almost dead center on the bottom front of the washer. Once you have unscrewed the unit, pull it out and clean out everything you see. Look inside and make sure there is nothing in the hose or the pump inlet hole. Reinstall and test for leaks before you put the panel back on. I recommend you clean this out every 6 months. Good Luck,
Appliance Specialists
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Inside paddle fell off
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top.Rotate the drum around and reach inside the drum. Re-attach that baffle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Whirlpool LER5636P Electric Dryer
Noisy dryer
tis possible that cons have gotten stuck within the veins( tub paddles) of the dryer drum, if thats the case youlll be able to rotate the drum around by hand and actually hear them tumble around as you turn them around.if thats the case tou will need to unscrew the tub baffles from the outside of the drum remove debris and resecure.DISCONNECT POWER SUPPLY
first remove 2 5/16 screws holding the lower access panel. and behind that panel 2 more 5/16 screws. lift that panel foward and it will release from under the main lid(2 clips holdin it in). mark the 3 wiresd and disconnect the door switch.2 final 5/16 screws in either corner is holding the main lid assy down, remove them and your able to flip the main top back. you now have access to the outside of the drum all you need to do is rotate around find the screws holding baffles and clean them out
Mar 29, 2008 | Dryers
I've had a model DLG330RAW gas dryer for 5 years. About 2 weeks ago it started making a sound as if coins were in the barrel. It wasn't the clothes buttons, zippers, etc as it will still make the noise...
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Dan Webster
Dan Webster
