Matched 1 double get 0 credit on 5/11. Matched 4 doubles get 3 credit & 1 doubles get 0 credit on 5/12. Tonight 5/13 matched 3 doubles get 1 credit & 2 doubles get 1 credit.
SOURCE: Double vision display
sounds like you have one or more bad LCD panels in the projector. replacement of the panels will fix the problem, but the cost of the panels is around 500.00 each; there are three panels.
SOURCE: Doorbell doesn't work
Have you tried to bring the remote (Push button) into the house and go to where the receiver is located and see if it works. It can be hard to see the battery polarity positions in the remote. Check to be sure that the battery is in correctly. If you cannot bring the remote into the house, try relocating the receiver to a receptacle closer to the entry. If all this fails, try buying a replacement remote (button) and matching the code pin settings.
SOURCE: mahjong quest expeditions, double triple towers!!!!
I am very sorry, but I don`t think we should be giving you answers for gameplaying. Only technical.
Try a gaming website
SOURCE: double vision
I'm assuming you have set the dioptre correctly for your eyes.
Normally this is caused by a collimation error when one (or both) prisms move. This can be by a small amount.
Your going to have to take them in for service/repair to fix this as is not a DIY problem. (Unless of course you have a collimator lying around)
SOURCE: headlight bulb replacement 2000 chevy malibu trouble
to replace headlight, on top of headlight assembly , there are 2 plastic slide pins one on each side. pull up on these slide pins to remove headlight assembly. then you can replace the bulbs. when putting back on , push in on headlight assembly and push the pins back down to hold assembly in.
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
