Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I want too open door on shabbos can't have light turn on
SOURCE: my oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Posted on Jan 06, 2008
SOURCE: Oven door that wont come unlocked
sounds like you have a latch/lock issue. the unit seems to think the door is still currently locked, preventing proper operation, i would try to see if you can locate the door/light switch and manually trip it with your hand(turning off light). then while keeping depressed activate the self clean mode again, the machine will try to engage the lock/latch, as soon as it does then cancel it and it will return back to a normal resting location. you must keep the light switched pushed in order for this to work correctly
Posted on Oct 07, 2008
SOURCE: Oven comes on when the door is opened.
One or more door switches is bad. Recommend replace all and have professionally aligned.
Eric
Posted on Jun 09, 2010
There probably is a bad micro switch that needs to be changed.
Posted on Apr 05, 2012
