Question about Sunpentown IM-150US Undercounter Ice Maker NEW
Its new hooked it up water comes to it but doesn't go to icemaker
Posted by Brad Bringhurst on
Hook up icemaker to water source
If you are doing a new installation, the icemaker should either come with an installation kit or recommend one. The kit comes with all of the hardware needed to basically "tap" into your existing cold water line. Your refrigerator is already prepped for the icemaker so it's just a simple bolt in operation.
Jul 28, 2014 | KitchenAid Refrigerators
How does the ice maker work: MFF2258VEW3
try filling the icemaker tray mold manually with about 4 ounces of tap water from the front of the icemaker,sometimes if you start a manual ice production harvest they will take over on their own after that
Dec 24, 2012 | Maytag Refrigerators
I disconnected icemaker to put in new floor, i hooked it back up, now my icemaker wont make ice. its going thru the motions but water isnt coming in.
does this unit have a water filter on it. may want to check filter if so alot of times when you turn water off there will be some sediment /trash come through system and could get lodges in line,filter assembly.. change filter out... you may also have some debri at water valve remove water line from vale and then check connection for any sediment prior to reconnecing turn water on to line holding a glass to catch the water. reconnect adn wait 6- 8 hours to see if ice maker fills with water...you can jump ice maker out by removing front cover and advancing timer.
Jan 02, 2011 | Kenmore Side by Side Refrigerator
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Trying to hook up a new line to the icemaker how do i know if the water is coming thruu properly?
before you hook up the line to the fridge, have someone open the valve to verify that water flows to the tube, once verified, hook to the inlet valve and your golden.
Sep 12, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Ice maker not getting water in the line
The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
Sunpentown IM-150US Undercounter Ice Maker NEW Logo
47 people viewed this question
Top Sunpentown Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
