Question about Sylvania DVR90VE DVD Recorder/VCR
Is there a firmware upgrade for a Sylvania DVR90VG that will allow using DVDrw 8X and 16X
Tried Verbatim DVD RW 4X and it still won't work give a error will not play back
Posted by Harry Gorman on
5 Related Answers
Anonymous
SOURCE: 16x DVD-R
I too need the upgrade for my Sylvania SRDV495. Could someone please send me the upgrade too or send me a link to let me know where to download if from. THANK YOU!
[email protected]
Amy
Posted on Apr 06, 2008
Anonymous
  • 3 Answers
SOURCE: Sometimes it can record on DVD-R Sony sometimes it doesn't.
So now I get an e-mail from Fix Ya asking me if I found a solution, if not they offer me a PREMIUM (Charge)Plan to help me solve the problem.
If I have solved my problem they want me to tell them how I fixed it for FREE.
Do you guys at Fix Ya use us as your employees to solve others problems and you collect the money? That is such a shame!
Posted on Jun 19, 2008
zimcloud
  • 135 Answers
SOURCE: Sylvania DVR90VF will not play home burned DVD-R disc
Search for DVD43 on the net. It's a free download. It works 99.99% of the time.
Posted on Jun 26, 2008
Anonymous
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I  learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch.  Thanks.
Posted on Dec 15, 2008
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: Where can I get an
Encompass parts has it for $7.62
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7810026&smodel=DVR90VG
Posted on Oct 21, 2010
Sony RDRGXD455 have tried both DVD-RW and DVD+RW discs from Phillips and they do not work. I have tried VR and Video modes. Do you think Verbatim DVD-RW discs would work?
It depends on what you are trying to record on them. These machines have copy protection built in. So if they detect that they won't let you record on the disc.
Mar 26, 2017 | Sony Televison & Video
Can you tell me some specific Brands of DVD-R or DVD-RW blank disks? I have tried several and cannot find many that will work with my Sylvania SRDV495.
There are no specific brands, however Verbatim are widely considered the best. Your, problem, however, is unlikely the brand of the media and more likely the recording speed of the media. Most blank DVD's on the market are 16x or faster and your machine (c. 2005) doesn't support anything faster than 4x. When I was reading the manual it referred to the "state of the art" 8x discs that the machine didn't have the ability to support. The discs you need are available and often are labeled as 2x - 4x meaning that they will support any drives that burn at a 2x - 4x spin rate. Also, be sure that you are not purchasing DVD+R and DVD+RW as they are not compatible with your unit.
Manual
Jun 22, 2011 | Sylvania SRDV495
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I'm unable to find DVD discs that will record in my machine. I was using Maxell DVD+RW 4x but am not able to find them. If it says "up to 4x" it will not work. If I buy Memorex 4x, they won't work. I saved...
I have found that the DVD recorder in this unit will not recognize a DVR+R disc greater than 8X speed. Therfore 16X discs are not an option. Like you already know, it likes DVD+RW 45X speed discs but it is selective. I have been using Maxell DVD+RW 4x and have found that Verbatim DVD+RW 4X and Sony DVD+RW 4X work just as well.
Jul 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
HR 720 does not burn to DVR -R media
Hallo everybody,
this guy "mysus" is a genius! I have had above problem on a Samsung HR-725 (160 Gb Version of the HR-720) now for approx. 1 year. I´ve called the Samsung Hotline and tried other dealers - nothing worked. Today I came accross this help and tried it out immediately - and it works perfectly. However, you do need to know a little about PCBs and electronics.
I used a variety of different -R DVDs and they all seem to work now. Many thanks once again for this fantastic link.
May 01, 2008 | Samsung DVD-HR720 DVD Recorder
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Error Message
The manual says to press the display button (just below the eject button) on the remote. This worked for me.
Oct 01, 2006 | Toshiba DR4 DVD Recorder
Sylvania DVR90VE DVD Recorder/VCR Logo
89 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
