Question about LG 60PA5500
Ho to fix Lg plasma tv no picture or sound
Heard loud pop TV went dark just clicks when hit power button
Posted by Toren Bogue on
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
Anonymous
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
Anonymous
SOURCE: LG 50PX1D 50 in. Plasma TV
i just had the same problem. after talking to many tv repair people i finally got a knowledgeable person to help me. i ordered the part and fixed it myself.
it was very easy. i have an LG model# 50px1d. so if you had this problem i suggest you order the part yourself and fix it. i got an estimate for repair and it wouldv'e cost me at least $500 parts and labor. i paid $230 for the part. so you can see i saved a little more than half. the part you need is the " Z SUS " ASSEMBLY. you can order the part from LG website. the part # is 6871QZH044C.
let's just say after doing everything myself, i am watching TV right now.
by the way LG would not help me at all. spread the word that LG is not a good product.
Posted on Feb 07, 2009
Anonymous
  • 3 Answers
SOURCE: lg plasma 42PC3D no picture with sound
I know you already replaced the board, this is for future searchers. If you heard a popping sound, then the picture went out, there is a 32 pin Sanyo module that goes bad on the board. That's probably what caused the fuse to blow. Replace the module, then replace the fuse. The module is less than half the cost of a used board. Since this was a popular model TV, there are lots of replacement boards on the used market.
Posted on Dec 31, 2010
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
LG 50inch Plasma received loud sound then went black
I suggest you guys take your TV's into a repair shop like Sears or Best Buy... The main reason most plasmas go dark is because of decay, but I don't think this is the case. Because what you describe is similar to what happens in LCD's when their back light goes out. Although you can open up and repair the back light your self in a LCD, I would not advise you to do so for a Plasma, because of the hazardous chemicals used in the plasma display plus the fact that plasmas don't use back lighting. And 2 years is way to soon for decay to be a factor. So more than likely a circuit shorted out and the TV has to be opened up to be repaired.
May 27, 2009 | LG 50PX4DR 50 in. Plasma TV
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Lg plasma 42PC3D no picture with sound
Mar 15, 2008 | LG 42PC3D 42 in. Plasma Television
LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 60PA5500 Logo
203 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
