Question about Kenwood Radio Communications
How do i open a kenwood th-234 battery pack? all the manuals i have seen shows a release lever in the battery pack. mine do not have one.
How do i open a kenwood th-234 battery pack? all the manuals i've seen shows a release lever in the battery pack. mine do not have one. im thinking that that this may be an older model of the Kenwood TH-234. Need help. Thank you.
Posted by Red Baron on
eradiostore
  • Kenwood Master
  • 1,658 Answers
If you are talking the battery pack itself, it is possible you have a NiCd battery instead of the Alkaline battery shell. If your battery does not have the locking tab to press on the battery pack, look for the part number and description on the battery itself and see if it matches what is in the user guide.
http://manual.kenwood.com/files/B62-0790-10.pdf
Best regards.
Posted on Jun 27, 2016
  • Red Baron
    Red Baron Jul 11, 2016
    thank you good sir...
2 Related Answers
Anonymous
  • 123 Answers
SOURCE: Kenwood VHF Portable TH 234
http://www.mods.dk/downloadmanual.php?RefFil=TH-234_235_Service_manual.zip&radio=
Try here,
Posted on Feb 28, 2008
Anonymous
  • 343 Answers
SOURCE: i need a manual for Kenwood TH-234
http://www.free-service-manuals.com/Kenwood_TH-234_Service_Manual_L72618/
Posted on May 08, 2010
Kenwood th-g71 amateur radio, audio very very loud, volume knob doesn't change the volume, I've tried a reset but that doesn't change the problem. This appen every now and than. Thank you mate.
It sounds to me that the volume control itself is defective. If the ground connection to the control opens, then the audio will do this. The repair usually is just a re-solder to the ground pin, or replacement of the control.
Sep 23, 2013 | Kenwood 9.6v Pb39 Pb-39 Battery For Th-g71...
Th-234 picture
if you meant kenwood th 234, than you just simply pull up the lock batterey on the left of hand held than swipe left the batt compartment
May 09, 2013 | Kenwood Radio Communications
I release the battery release lever but I cannot get the battery pack off.
You need to press and release the battery so that it clicks out of the hold hooks. Here is a copy of your manual. See page 10 of the manual:
http://www.cobyusa.com/files/manuals/TFDVD7100_MN.pdf
May 28, 2011 | Coby TF-DVD7100 Portable DVD Player
I need a manual for Kenwood TH-234
May 08, 2010 | Radio Communications
I Forgot code to my KENWOOD MP232 Car Stereo
i have the same radio the stock code on mine is 0000 try that ive also seen kenwood use 1234 or variants of it unhook the battery for a few mins and rehook it up it should reset the code to stock.
Jul 09, 2009 | Kenwood KDC-MP232 CD Player
My th-79a shows channel numbers only
RTFM Page 29
Press [BAND] + POWER ON to toggle Channel Display
Gerard - PE1OUD
Mar 04, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
How to remove the battery from lenovo T61 and put it back in?
the instructions below are from the owners manual page 69. you can download the manual with accompining pictures to guidr from the link below: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/42x3547_04.pdf
Table 11. Removal steps of battery pack Unlock the battery release lever 1. Holding the battery release lever in the unlocked position 2, remove the battery pack in the direction shown by arrow 3. 312 When installing: Install the battery pack along the slide rails of the slot. Then make sure that the battery release lever is in the locked position
I;ve spent my time to solve you're question, please show the good grace to at least take a few seconds to rate this answer.
Feb 01, 2009 | Lenovo ThinkPad® T61 PC Notebook
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Radio Communications Logo
244 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Lawrence Oravetz
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
