Dyson AM04 Hot Cool Fan Heater White Logo
Question about Dyson AM04 Hot Cool Fan Heater White
I need to return the fan to qvc. When i try to remove the flat part the base goes into, I'm unable to do so. I removed the base from the blade w/o any p roblem.
Posted by Birgit Seide on
Marvin
    Top Expert:
  • Dyson Master
  • 85,241 Answers
We are not QVC.
Posted on May 13, 2016
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
I need to raise the ceiling fan, can I remove the small bar to get it closer to the ceiling?
you can, but the base may change the balance. use small pieces to balance the blades--it should not take much
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Oct 01, 2014 • Dryers
How to disassemble lasko hassock floor fan
I'm assuming you want to open the fan up to give it a thorough cleaning. This is how I got one open. First things first, make sure it's unplugged. No need to risk zapping yourself of accidentally turning it on when your fingers are in range of the fan blade...
Turn the fan upside down. There are four very long Phillips screws concealed by long plastic sleeves that cover the shafts of the screws, with the ***** heads covered by the rubber feet at the bottom of the unit. Pop out the rubber feet, then loosen the screws (there will likely be an alarming snap when they break loose). The two-piece top of the unit will come loose. You can then remove the screws and the plastic sleeves that hide the screws.
Turn the unit right side up and remove the fan blade. The nut holding the blade on is reverse thread, so "lefty loosy, righty tighty" will not apply--turn the nut clockwise to loosen. Remove the nut and lock washer, then pull the blade from underneath the hub (it'll take a bit of force to pop it off.
The wire from the motor to the speed control switch connects the base to the cylindrical center portion of the unit. To separate the center portion from the base, pull the knob off of the shaft of the switch and remove the ***** holding it in place. The switch can then be disconnected from the center piece. I'd put the ***** back into the switch to keep it from disappearing.
The motor can be removed from the base by removing the three screws holding it to the base from underneath, but unless you're looking to replace the motor, you shouldn't need to do this.
Put it back together by reversing the disassembly process.
1helpful
Fan blade goes what direction on 2001 Honda passport. I was repleacing clutch and forgot which way it goes. blowing foward or towards the engine?
The blade should be facing in the direction to pull air in and over the engine. You should have some tell tale sign on the base that will give an indication of how it was mounted before removal, such as bolt or flange marks.
9helpful
2answers
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 • Blenders
1helpful
2answers
We have a hampton bay fan and can not get it off the ceiling how do you remove it?
I have no experience with ceiling fans and for me removing the housing didn't get me anywhere. For our fan (Model 23758) there was a nearly invisible ring of material at the base of the fan where it meets the ceiling. This was in place for apparently aesthetic purposes as it hid the screws that secured it to the ceiling bracket. By rotating this ring and pulling down, we were able to to remove it.
1helpful
3answers
Removing fan blades
Joey Temal is right. After removing any small metal retaining clips (which are obvious and easily removed), you have to pull down ridiculously hard to get the fan blade off. Alternate short jerky pulls with steady downward traction.
30helpful
Need to remove gril to clean blade and grill
You can remove it by pressing the clips. I used a flat screwdriver as there was no way my thumb would fit in there. But it worked like a champ with the screwdriver. I pressed two clips and it popped and then I could simply lift the grill away from the fan blades.
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
