It's a firmware error, usually caused by a corrupt print job (usually adobe). Install the newest firmware and you want to experiment with different driver - PS if the docs you are attempting to print are pdf
Suggestible for tech guys: Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. If its look like difficulty, replace star wheel unit..
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: - http://welcome.hp.com/country/au/en/cs/support.html
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Vamos abra a maquina, retira o cartucho, do lado esquerdo tem uma alavanca preta (do lado de dentro da maquina), empurra ela e segura, vai com uma chave de fenda e fecha o sensor de tampa aberta q se localiza do lado esquerdo da parte da frente da maquina, apos vc fechar o sensor a maquina ira fazer o auto teste, e vai mostra Toner erro, coloque o cartucho novamente, delique a maquina fecha a tampa e liga novamente.
