Harness has 1 red / white stripe and yellow / blue stripe rapped in braided wire What goes where
What is the question?
Testimonial: "What plugs into what bl / gr to what red / w to what 02 sensor 2 w. 1grey. 1 black"
The plugs are coded, so you can't really mes it up right?
What 2 are heat what one is signal what is ground
I have no idea, don't have a wiring diagram at my house.
Plug burnt off harness know 2 wht on 02 is heat
Black is ground the other must be signal.
Did you google to see if anyone has a diagram of wire colors?
How about youtube. Many other sources of info besides us.
Looking all day
Need to know what the harness wires are
I am sorry but I do not have that info here. Try eBay for a used wiring diagram book.
SOURCE: I'm having trouble installing a radio in my 1992 toyota celica
go to any auto parts store and ask for a 12 volt test light, it has a bulb inside and a pointed end like an ice pick, u attach one end to a good ground and then probe wires for power, when u have a hot wire with 12 volts the light in the handle will shine on. They cost about $6.00 at Kragen I think.
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
SOURCE: i need the radio wiring diagram for a 1992 cadillac eldorado
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
SOURCE: Hi, im searching for the stereo wiring chart for
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Hi Stan cramer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Since every car & truck is different, please share the year, make, and model of the vehicle to start giving you an answer.
1999 Hyundai Elantra
