When pushing the power button to power the receiver on, the receiver you can hear the click sound and the fan goes around for about a few seconds and then stops and the receiver does not come on at all. Do you have any Idea on a reset or something that can be done here to resolve this issue and get this receiver back up and running? Any help will be greatly appreciated. Thank You. Ron
SOURCE: Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
SOURCE: Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
SOURCE: Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
SOURCE: Wont turn on
The solution is to replace the main power relay. I
ordered a replacement relay from Vance Baldwin Electronics - part RELAY
DC DG12D1-0/M11 RXV2095 (V6881300). After installing the relay this
morning, my receiver now stays on continuously like it is supposed to.
You can easily fix this yourself in about an hour. All you need is a
screwdriver, a soldering iron, and some solder.
Regards,
Chaz
