I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
