Question about HP Deskjet 3510 e-All-in-One Printer
It ink cartridge when rolling to the other side it's hitting the other side hard.
It's not printing or coping anything. It just keep going from side to side.
Posted by Barbara Sanders on
micky dee
  • HP Master
  • 3,015 Answers
Check out HP support for this model
HP Deskjet 3510 All in One Printer Software and Drivers
Posted on May 11, 2016
5 Related Answers
Anonymous
SOURCE: Computer won't recognize a replaced ink cartridge
This is what worked for me today..
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One. If the issue persists, please perform the next troubleshooting steps
Courtesy of Joe at HP via an email
Posted on Nov 10, 2008
ipi4u
  • 3 Answers
SOURCE: hp officejet 4215 all in one printing very light black ink, new cartridge
you must change your printer settings to the default settings.
Posted on Dec 03, 2008
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Posted on Dec 12, 2008
Anonymous
  • 2120 Answers
SOURCE: Replacement ink cartridge printing like low ink
It's dried up inside of the cart.
Posted on Jan 29, 2009
Anonymous
  • 106 Answers
SOURCE: Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Posted on Feb 16, 2009
Why does my printer keep telling me to take out and replace the cartridges when there is plenty of ink in them?
This often happens with refilled ink (or toner) cartridges. Inside the cartridges are certain electronics that are designed to last only a certain amount of time. Refilled cartridges do not replace these electronics most often, so after they have been recycled a time or two, they go bad and you end up having paid for a cartridge that will not communicate with the printer. This ends up with the printer telling you that the cartridge is empty, incompatible, or some other warning that disallows you from printing. The best option is to contact the company from which you bought the cartridge and have it replaced.
On another note, be aware that original cartridges for inkjet printers are highly recommended for use because the ink within them not only is ink but also has a bit of lubrication within it that keeps the spray nozzles free of dried ink and, therefore, keeps your print quality at its best. If you wish to save money on cartridges, then most professionals recommend alternating between original and refilled cartridges.
In the world of laser printers, good quality refilled cartridges are just fine to use on a constant basis a toner is nothing more than plastic powder that gets heated by the fusing assembly and melted onto the paper. There is nothing to lubricate parts within it. The only issue is to make sure that you get your cartridges from a company that provides quality units. Lesser cartridges can leak toner that can make a mess inside the printer and/or on your print jobs and can damage the printer. However, unlike popular belief, using refilled toner cartridges will not void your warranty. Rather if any damage is caused by said refilled cartridge, it will not be covered by the warranty but the warranty will remain in effect for anything that is so covered.
I have found that a site called CompAndSave.com (
Ink Cartridges Printer Ink Toner Cartridges HP Ink CompAndSave ) has very good toner cartridges, so I recommend them. I've not had the opportunity to try their inkjet cartridges as I have only laser printers and sell only toner cartridges to my clients but I would think that their quality would be just as high.
I hope all this helps. Let me know if I can assist you further.
Sep 29, 2014 | Computers & Internet
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
Just changed ink cartridges and unable to use printer. Keeps stating printhead missing or has come loose but it isn't. Before this happened, wouldn't print the black ink after I'd installed...
Hello
Your printhead is bad and you should have it replaced.This should cost you about $56 if you are in the US
Also you should reolace all the waste ink absorbers,reset the counter to zero and re-insert the ink cartridges.
To replace the ink cartridges
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Jun 12, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Printer taking hours to make a print
Check if you are able to make a copy from the printer, it will clear if it is a hardware issue.
If it is hardware, then you need to check it by replacing the cartridge, revert back.
Apr 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printing and coping with vertical lines of varing shades of gray with a black line approximately 3 inches from the top and this did not start until I bought a new toner
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 14, 2010 | Brother MFC-7440N Laser Printer
With WorkForce 500, I am using only black for coping. But other color inks become low and the coping is stopped. Are there any way to do only the black coping?
replace all color cartridges with black toner
if ink fill your color cartridge with black ink using a refill kit
and just buy a new color cart and keep it asside in a zip lock untill you need color
Aug 03, 2009 | Office Equipment & Supplies
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
Lex 5150 - not printing black well
what you may have to do is clean the rollers, good place to clean is where you insert the cartridges, open the lid so the machine thinks your going to repalce the ink, cut the power from the mains, now you can proceed to to clean the inside, remove both in cartradges and clean where they instert, toilet roll or kitchen roll will do because they soak up the ink, then, and be very gentle, slide the mechanism to the left hand side so you can clean underneath, after cleaning power the printer up so that it still thinks you are changing the ink, the cartridge housing should be where you can access them so you can the put the ink back in, then you need to use the the lexmark software to re-align the cartridges and also print a test page, keep on doing this until the inkjets are performing properly
Nov 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
