Durabrand DUR-1700 Portable DVD Player Logo
Question about Durabrand DUR-1700 Portable DVD Player
Working properly, however, the screen cut out. pressed button marked "monitor" but screen still not working. Still can 'hear' dvd, cannot 'see' it
Posted by KIM BENNETT on
1helpful
Blank screen
There is a function called "Monitor Off" that may currently be activated. Please press the [LCD-SIZE] button repeatedly while playing a disc.
My pc is switched on but the monitor screen is blank. why?
Since you didnt give enough info i'll assume its a windows PC.
Did you hear the sound from the window startup? most windows PC have this sound.
If you do, check your monitor cable. Is it connected properly to motherboard / graphic card output?
If connected properly and the cable are fine then press menu > source (try all source one by one or simply auto if you are not sure which one) button on your monitor.
If you cant even see the menu on your screen after pressing it then your monitor are broken.
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
NO DISPLAY on screen but processor fan is work
If it seems like the computer booted up all the way except the screen is blank.
If so try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok and works, then the video card inside the computer is good, but the original monitor is bad. If the Borrowed monitor does not work, then the video card inside the computer is bad.
If it does not seem like the computer booted up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
1helpful
Mouse keyboard and monitor dont work upon power up
If it seems like it booted up all the way except the screen is black try the steps below.
Either the monitor or the video card inside the computer is bad. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If it does not seem like it booted up all the way try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Asus p5lp-le no display
If it seems like the computer completed the boot process but the screen is blank, try the steps below.
The problem will either be the monitor or the video card inside the computer. Connect another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad and the video card is good. If the Borrowed monitor does not work then the video card inside the computer is bad.
If the computer did not complete the boot process then try the steps below.
Desktop runs but won't boot
Normally if the hard drive is bad you will get some type of message on the screen.
If it sounds like it is running but the screen is blank, then try another monitor. Maybe the monitor is bad. Try another monitor. Borrow a monitor from a neighbor, friend, relative or co-worker and put it on the computer. If the borrowed monitor works, then your old monitor is bad. If the borrowed monitor does the same thing, then your video card is bad.
If it does not seem like it booted up all the way then try the steps below.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Won't boot
1helpful
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Black screen
It really sounds like the child lock has been activated. This uaually blocks the keys on the TV, but the remote should work. If your remote doesn't work either, make sure the batteries work. If your remote for the TV can operate other apliances such as a VCR or DVD player, make sure it is in TV mode. If there are any buttons marked TV, VCR, DVD you could try pressing the TV button to set it in TV mode. If the To has a text-tv function there might be more than one button marked TV; one for setting TV mode as posed to DVD operating mode, and one for getting TV picture back when viewing text pages. -Chris
Top Durabrand Televison & Video Experts
Marvin
Marvin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
