Question about Brookstone Audio Players & Recorders
My brookstone bluetooth speaker volume is very low the volume it's up to the max and it's still plays low what can I do
Posted by Kevin greenslade on
FrostByte Network
    Habit-Forming:
    New Friend:
  • 72 Answers
Check your mobile device or laptop. The volume might be low there.
Posted on Oct 31, 2016
4 Related Answers
Anonymous
SOURCE: Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Posted on Jul 02, 2009
Anonymous
  • 20 Answers
SOURCE: Exact same problem; low volume
1st check your PC if audio is fine with headphones or some other speakers , then check your control panel and test sounds compatibility might that you are using wrong speaker setting in the PC.
The below is the company web link to your speaker set , try this too
http://www.polkaudio.com/homeaudio/specs/recent/amr50/
if nothing works please msg me the exact config of ur PC
Posted on Aug 02, 2009
Anonymous
  • 1555 Answers
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Posted on Aug 04, 2009
SOURCE: Rear speakers' volume of X-540
In order to do this, your computer must be able to support 5.1 systems! Seeing as how a person wouldn't buy this particular set of speakers without knowing that information, I'm guessing you have a bit of knowledge under your belt. You need to go into your audio device settings on your computer and you should have the ability to tweak the settings of the rear speakers from your audio controller panel. I myself have the EAX which allows access to adjusting the speakers volumes based on distance from the listener!
Posted on Sep 02, 2011
Volume on my iHome is too quiet, fix please?
You an inline battery powered signal booster, they are cheap.
After device has been paired and connected but there is no sound coming from speaker what do I do?
Play music or video file on the Bluetooth device you paired and connected with the speaker and you will get sound coming out of the speaker.
Big blue won't pair with iPad even though the iPad shows it's discoverable. Also, when I connect speaker it ipod using cable, it beeps but won't play.
That's because the speakers are broken. Look in the User guide for reset instructions. If that doesn't work buy new speakers.
1helpful
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
My bluetooth brookstone ipad keyboard is not working
The iPad's touchscreen keyboard isn't bad, its actually pretty good for a touchkeyboard. However there can be times where you may need to do some major emailing or even document writing and need a keyboard. This recipe will show you how to pair any bluetooth keyboard with the iPad. You don't just need to use the Apple one, any bluetooth keyboard will work!
1. Go to Settings - General
2. Tap on Bluetooth, if its Off, tap on it to turn it On.
3. Now put your bluetooth keyboard in pairing mode; usually a dedicated button or by holding the power button down for 5 secs.
4. Once you do this, your keyboard will show up under Devices and say Not Paired.
5. Tap on it, You will be prompted with a message to type a series of numbers on the bluetooth keyboard and then press Enter on the keyboard.
6. The keyboard should up under Devices and say Connected.
Tips:
-If your keyboard has a volume controls and media player controls (ie play, next, pause, prev, volume, mute), they will all map in the system and work in iPod and Videos and control the system volume. These will also work when your in an app with the music in the background (ie Safari, Pages, Mail, Calendar, any of the native apps)
-The Internet Home button on some keyboards will act like the Home button. My Dell BT Keyboard w/media/internet controls works like this.
To Unpair:
Go to Settings - General -Bluetooth, Tap on the arrow on your keyboard in the list. Tap on Forget this Device
hope this
Bluetooth volume too low Go730
You are out of luck...I have the same unit and it wont even connect with my LG Voyager! the volume doesn't want to cooperate with anything I think it should do. I actually went with a wired headset to answer call once it did connect and forgot about the whole speaker thing.
2helpful
3answers
IPhone 3G Bluetooth microphone volume to low
This is a Normal problem, remeber the echo is for the mircrophone is in the same place like the speakers, & dont have a noice cancelation system, I recomended to use a bluetooth earphone
2answers
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
48helpful
11answers
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Top Brookstone Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Mike M
Mike M
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
