You can't. It is hard wired in programmed memory. The reason is because most Xerox printed are supplied on a consumables deal where you have to buy toner direct at a slightly inflated price to cover the lowered lease cost of the machine. These machine also 'phone home' for interrogation..
Xerox 7435 error code 041-340 indicates a problem with the yellow imaging unit. Here are some steps to solve the error:
Power off the printer and unplug it from the power source.
Remove the yellow imaging unit and check for any damage or leaks.
If the imaging unit appears to be in good condition, reinsert it firmly and make sure it is properly seated.
Turn the printer back on and check if the error message has disappeared.
If the error persists, try replacing the yellow imaging unit with a new one.
If replacing the imaging unit doesn't solve the problem, you may need to call a technician to troubleshoot the issue further.
It's worth noting that error code 041-340 can also be caused by issues with the developer housing, toner cartridge, or other components. If none of the above steps work, it's best to contact Xerox support for assistance.
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
