Passenger side ttop wont unlock,key turns but wont ulock.I have tried pb blaster but it wont unlock,also my key remote needs batteries, is there things that only work with key remote
May need to replace...but first try spraying a little PB Blaster on key and into key slot to lubricate...other solutions may damage...but PB Blaster will make cleaner connections and movement...Hope this helps.
go to any auto parts store and look for pb blaster.spray around where the hub and rotor meet .let it soak-maybe overnight.then use a block of wood and a heavy hammer(if you dont want to damage the rotor)work your way around the rotor.clean everything with brake cleaner after.PB Blaster is what us pros use.
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
How do you know the replacement switches were good? These actuators work in a series...One could be defective, causing the others (including drivers door) to not work...Also try cleaning all contact points with PB Blaster, and wipe dry...Hope this helps.
A seized up door lock actuator. You can try freeing it up by spraying a good penetrating oil, my favorite is PB Blaster. If it wont free up you will need to replace it.
Spray some PB Blaster or a quality rust pentrant into the lock, on the sides of the outside handle and upward on the sides of the handle, dont be shy with the oil. Let sit for 15-30 min, make sure the doors are unlocked, take a rubber mallet and rap on the handle and around the area of the handle at the same time your lifting up and releasing the handle rapidly. Has work on about 4 Monteros, Good Luck
really sounds like the tumbler pins are stuck in the cylinder of the lock. mite want to spray some lubricant like(PB Blaster)or WD-40 in the cylinder key hole and push key in and out to see if tumblers will release..gd luck..chris
your key is probably worn down and needs replaced, but you can try spraying a penetrating oil (WD40 or PB Blaster) into the lock cylinder this sometimes works
