Photos are okay they don't have horizontal lines on them only the display screen has the horizontal lines
The LCD in the viewfinder likely has connection problems or broken circuits. Did you drop it recently? Was it subject to extreme temperature etc recently? You may find the lines shift around or even go away for some time. That would imply bad connections. If your technical enough to disassemble it, there is often a rubberised connector use between the LCD and circuit board that can be cleaned. It's delicate work tho.
