Omega 8004 Juicer Logo
Question about Omega 8004 Juicer
Auger is stuck to the base, it wont detach!
Posted by Leonor Berdichevsky on
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 • Blenders
1helpful
Stuck
The problem is: when last used, the contents of the container may have spilled over and seeped into the tab switches along the interior well of the unit. The tabs will not release the container as they are STUCK. Try a spry mist of window cleaner around the base of the container and let sit a short time. Try to move container around several times and see if it releases. It will not come out easy, and if forced, the entire unit will be damaged. Also, the hard rubber connector that engages under the container can become misaligned and when off center, it will bind up.
Blender Base is stuck and won't budge
Please use the WD-40 and let by 1 hours, and ready.
God bless you
Base of my blender won't detach
please use the WD-40 for to loose and Ready.go www.40company.com
God bless you
4helpful
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
1helpful
Blade not spinning
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
1helpful
Top Omega Blenders Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you an Omega Blender Expert? Answer questions, earn points and help others
