Question about Vizio 70-inch LED Smart TV M701D-A3R 3D Razor HDTV bundle with SB4021E-B0 2.1 Sound Bar and 3D Glasses
How do i fix my smart tv
When i turn on my tv i can hear whats on the tv but theres no picture
Posted by Yari Aponte on
Electro Med Services
  • Vizio Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Posted on May 07, 2016
  • Larry Sep 07, 2021
    NO usable advice here!!!!
Larry
  • Vizio Master
  • 3,201 Answers
Your LED backlights have failed, it's not a board or component issue. You can order replacement lamp strips from shopjimmy.com, view a few youtube vids on some points on how to replace them, anyone can do it, but it takes some patience and caution when handling the panel. Good luck
Posted on Sep 07, 2021
2answers
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
2answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
1helpful
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
How do I fix the bright and colour of 42"lg smart tv
I believe you will have to turn off Smart Picture to adjust the picture settings. Use the Home button on the remote to enter the menu. Then use the arrow buttons to select what you want to adjust, then the Enter or Ok button to select it, then the arrow buttons to adjust.
2answers
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
2answers
My Samsung 46" smart tv keeps switching picture into dynamic when using smart hub or when changing from tv to av please help me fix this
It means your tv is in shop mode. Turn it off by pressing Info button on your remote control then follow from there.
TV has audio sound and no picture
major repair; requires 16 pin ic
Trung,
There are many possibilities and most of them have to do with the "D" board, Sony p/n# A1346948A but testing is something generally beyond the scope of those less than technically equipped. You could order the whole board and put it in but that might be more than the simple fix you wanted or you wouldn't be here. So my best advice is to take it in to a qualified shop and have them estimate and repair it.. I see 3 or 4 of these sets in my shop a month, Sony XBR, and they're still very much worth the repair..
Bill
Vizio 70-inch LED Smart TV M701D-A3R 3D Razor HDTV bundle with SB4021E-B0 2.1 Sound Bar and 3D Glasses Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
