Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Maytag Neptune MAH4000AWW washer door will not unlock
Hi, I have a Maytag Neptune MAH4000AWW washer. It is about 8-9 years old, and we have never had a problem with it.
Just two days ago, the washer has started exhibiting a strange symptom.
At the end of a load, the washer has always done some intermittent slow spins, no more than 15 mins or so, and then shuts off and unlocks the door.
Well, now, the washer gets stuck in this slow intermittent spin cycle and never finishes! Door remains locked. Sort of like an endless loop. So I unplug washer and wait 18 minutes like an appliance store says, and now the door is unlocked. I did some digging and found out about the control board and wax motor problems. Checked out the control board....and both R11 and Q6 appear to be fine. No obvious scorching, etc.
My thought was that I have to replace both the control board and wax motor, but at $215 for the both of them, I think that is a last resort. Could this problem be something simpler? This washer does not have a display to show error codes or anything like that.
Any ideas would be great. Thank you for your time.
Posted by ionic-fire on
  • ionic-fire Nov 20, 2007
    How would I go about trouble-shooting? Perhaps I should order the Maytag service manual?
Doug Camburn
    New Friend:
  • 122 Answers
Check the spin enable switch. there is a seperate switch for the lock light and spin enable. if the actuator doesn't extend fully it won't hit the switch. or the switch is bad. It's located in the door latch assembly.
Posted on Jun 15, 2010
  • Doug Camburn Jun 15, 2010
    don't replace the board unless r11 is burnt. If the lock lite is coming on it's probably not the board.
prem mathew
    President:
  • 1,294 Answers
Try changing the motor brushes, available at:
espares.co.uk or RepairClinic.com
Posted on Apr 01, 2008
Anonymous
  • 213 Answers
No, the board and wax motor is one possible problem but more likely youll need the motor kit with spped control. even more expesive but prove to be a big problem with this washer
Posted on Nov 19, 2007
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag neptune washer
Drum capaicty is 3.34 for the Neptune Model # MAH4000AWW
Dec 27, 2008 | Maytag Neptune Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
823 people viewed this question
Marvin
Marvin
Ned Halaweh
Ned Halaweh
