Whether it's a *.pdf file or not, as soon as 1 programme can display the content of the manual, the same programme should be able to print it. e.g. print from adobe accrobat reader directly. Otherwise install the "open office" suite (costs 0) to open the manual file. that software should be able to print the content. (make sure the printer is correctly installed on your system.)
Hi, when this happens it usually means the operating system is corrupt, the best thing to do is to reflash your Archos, you obtain the required software and then plug into the USB port and then using the proprietary software to reflash the internal memory on the Archos to replace the operating system, and restore it to functionality, if you ONLY copy over the system files you will keep all you old settings.
You need to go to the Archos website to obtain the Firmware also there is s "How to" reflash your Archos 7.
Is your laptop connected to a printer? Is the printer working? I will assume your answers are "yes".
Have you downloaded the "manual"? Or is it simply listed as a document on your computer? Is it a word or PDF file? Again I will assume your answer is "yes" and it is either a "word" or PDF file. If not download the document from the Toshiba support website to an easy to find location on your computer.
Either way, open the document (manual).
Either using the "printer" icon located along the top of the document or click on "file" and you will see "print" in the drop down menu. Either way "Click" on it and your document will be printed. It may "open" another window verifying which printer to use. Simply make sure the printer you want is high lighted and follow the prompts. Make sure you have enough paper in the printer if it is a large file.
You can also drag the document to your printer icon and it to will achieve the same results.
It's that simple. Good luck and happy reading your manual.
