Question about FoodSaver Food Saver Vacuum Sealer SmartSeal V3460
The tray light always stay's on
Look's like it's full but it is dry
Posted by Eric Chamberland on
2 Related Answers
Lawrence Oravetz
  • 10548 Answers
SOURCE: foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Posted on Jun 07, 2014
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Foodsaver vacuum sealer tray full light
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Sep 26, 2013 | FoodSaver V3835 Vacuum Food Sealer with...
Just had my dc24 for 6 weeks - decided to wash filters - do the filters stay in their plastic covers? They were a bit dirty but no visible dirt came out when \i washed them \9in their plastic casings). ...
To confirm, the filters do stay in their plastic casing when you wash them.
You may find it helpful to refer to this Dyson video guide, which demonstrates each step in the filter wash process: http://www.dyson.co.uk/support/help.asp?article=1943&product=DC24-ALLFLOORS
Always allow up to 24 hours for the filters to dry completely before refitting them.
I hope this information is useful to you, if you have any further queries, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Mar 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
Light saying bag full and clogged have changed bagand checked for blocks cant find anything.
OK - blockages are not always obvious (especially if they are deep within the flexible hose). One thing you can try is to remove the flexible hose from the top of the bag compartment and then switch on - if the red light goes out, there's a blockage in the hose. If the light stays on, there's almost certainly a problem with the main circuit board (for which you should get professional help) but that would be extremely unusual. If you need further help, please post a reply here and I'll do what I can.
Feb 28, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Check brush lite stays on after brushes have been checked
Make sure that the filter is dry and properly installed. Usually that's what causes the "check brush" light.
Aug 23, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Apr 15, 2008 | Vacuums
FoodSaver Food Saver Vacuum Sealer SmartSeal V3460 Logo
57 people viewed this question
Top FoodSaver Vacuums Experts
ray gallant
Larry Ng
Larry Ng
Lawrence Oravetz
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
