Question about Paradigm Audio Players & Recorders
Paradigm PS 1200 sub won't pass sound and only hums? Anything I can do?
Posted by Gary Mattingly on
2 Related Answers
Anonymous
SOURCE: Our ten year old paradigm ps 1200 subwoofer does
Disconnect the power, pull the amplifier out by undoing the screws that hold it in.
When you pull it out, look closely towards the top there is a little 1.8A fuse. It probably has blown.
Replace that and you should be back in business.
Posted on Sep 27, 2010
Lawrence Oravetz
  • 10548 Answers
SOURCE: How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Posted on Dec 31, 2014
What is the impedance of the 12" driver in this subwoofer
PS-1200 Specifications
Design
Single driver, DCBS™ system with high velocity resistive ports and built-in amplifier Amplifier High current, hybrid output, 130 watts RMS
Amplifier Features Powersaver auto-on/off, soft clipping, thermal protection Low Pass Filter Frequency Variable 50Hz-150Hz Low Frequency Driver 310 mm, carbon-fiber-reinforced composite cone, Apical™ former Low Frequency Extension 23 Hz (DIN) Sub / Sat Phase Alignment 0 - 180 Finishes Black Ash Inputs From A/V receiver/processor or Paradigm X-Series Control Unit or preamp left/right output; From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 68 lbs. (31 kg) Dimensions HxWxD 19.75" × 17" × 21"
(50cm × 43cm × 53cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
1helpful
Ps-1200-A sub woofer will not power up
Probably a blown fuse. If there's not one on the face of the amp, pull the amp and check for one next to the power cable.
3helpful
Our ten year old paradigm ps 1200 subwoofer does not power up, although it is plugged in and properly connected to the receiver. Why is this? Is it a lost cause?
How long should a powered sub woofer last? It's on 24/7, but is not abused with long, loud playing. Mostly regular TV.I have a Paradigm PS1000, about 10-12 years old.
There's no way of telling really! Even if something did go wrong there's no reason to say it couldn't be fixed very cheaply. It could last another 10 years or it could go wrong in the next few hours.
I will say one thing after 12 years of service and never off you certainly have had your monies worth!
I have a ipod i would like to connect to my PS Series but i do not know how
Don't bother. A subwoofer will only reproduce the rumble (deep bass) end of the spectrum. You would still need other (full range) speakers for the rest of the frequencies.
But, if you must - get an adapter to convert the Ipod's headphone output to an RCA pair and jack it into the sub's inputs.
2helpful
2answers
PAradigm ps-1000 subwoofer
It turns out its most likely one of the resistors on the PCB on the amplifier plate.
My uncle has had the same problem and managed to replace the resistor and its working as normal now.
Power source
I have PS-1000 and same problem. It looks like power transformer got partially shot (reads 11 V AC instead of 56)
I just don't know if it's all the problem or there is something else. And where I can find replacement transformer?
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
